查看: 318|回复: 1
[HyperStudy] Hperstudy调用ANSYS/ls-dyna
发表于 2012-12-12 17:01:44 | 显示全部楼层 |阅读模式 来自 安徽合肥
在Hyperstudy中如何调用ANSYS软件中的ls-dyna作为求解器?到底能否调用,是不是只能调用单独的ls-dyna软件?
发表于 2012-12-13 08:19:24 | 显示全部楼层 来自 韩国
不是很明白楼主的意思。。如果实在hyperstudy 中调用ls-dyna求解的话,可以参考以下内容:
In order to use LS-Dyna as a solver, you need to register it in the preference file for HyperStudy.
1. Go to the Tools pull-down menu.
2. Choose Register Solver Script….
The Register Solver Script window appears.
3. Click Add….
4. Enter the Label: Dyna.
5. Enter the Variable: Dyna.
6. Browse for the Script:.
7. Click OK.
8. You can now save the change to a new user preference file by using Save As… and providing a name (userprefs.mvw, for example).  Be sure not to overwrite the system preferences file which is located in <install_directory>/hw by default.  In UNIX, the preference file can also be located in your home directory or in the working directory from which you launched HyperStudy.
9. From the File menu, choose Set Preference File… and select the preferences file that you just saved.
HyperStudy will read the default preferences file in the installation directory, followed by the preference file that you specify.  This will ensure that all readers and import templates are available.
You can also append the current user preference file using Append, or you can exit the solver registration using Close.  In the last case, the solver will only be registered for the current study.
GMT+8, 2024-10-3 07:44 , Processed in 0.029337 second(s), 11 queries , Gzip On, MemCache On.
