在classic中plot单元表很容易,而且可以通过命令行实现单元表的运算。在workbench中如何实现呢?
我查到外国网页有这样的介绍,但是却搞不明白是怎么实现的,是把命令行加在solution后面,然后运行吗?
“Since 11.0 Workbench creates file.rst for results, your best bet is to use classic ANSYS for element tables, etc. However, if you insist on using Workbench, refer to Simulation Help | Using Simulation Features | Commands Objects. You will need to insert a Commands object under Solution with the appropriate ETABLE and PLETAB commands:
