在计算时看到out文件提示了这些存储,但是不知道各种存储的作用。请问能否解释下?
Current Memory (RAM) : 2947 MB
Estimated Minimum Memory (RAM) for Minimum Core Solution: 2822 MB
Recommended Memory (RAM) for Minimum Core Solution : 2947 MB
Estimated Minimum Memory (RAM) for Out of Core Solution : 6742 MB
Recommended Memory (RAM) for Out of Core Solution : 7525 MB
Recommended Memory (RAM) for In-Core Solution : 38639 MB
Recommended Number of Nodes for OS SPMD Parallel Run : 6
(Note: Minimum Core Solution Process is Activated.)
(Note: The Minimum Memory Requirement is limited by Assembly Module.)
(Note: Use param,HASHASSM,yes to avoid assembly module memory bottleneck)
DISK SPACE ESTIMATION INFORMATION :
Estimated Disk Space for Output Data Files : 15317 MB
Estimated Scratch Disk Space for In-Core Solution : 78905 MB
Estimated Scratch Disk Space for Out of Core Solution : 115003 MB
Estimated Scratch Disk Space for Minimum Core Solution : 119581 MB
