查看: 88|回复: 2
[问题讨论] 薄膜收敛问题
发表于 2013-2-18 22:18:53 | 显示全部楼层 |阅读模式 来自 北京
薄壳收敛问题,当壳的厚度比较大时可以收敛,小的时候就不收敛了。膜厚度R,1,0.03, , , , , ,时收敛,但是R,1,0.03/10, , , , , ,不收敛,我给它加了阻尼,但是不起作用。
下面是我的命令流
FINISH  ! Make sure we are at BEGIN level
/CLEAR,NOSTART  ! Clear model since no SAVE found
/PREP7
BOPTN,KEEP,0
BOPTN,NWARN,0
BOPTN,VERS,RV52
BTOL,1e-005,
/PNUM,KP,0
/PNUM,LINE,0
/PNUM,AREA,1
/PNUM,VOLU,0
/PNUM,NODE,0
/PNUM,TABN,0
/PNUM,SVAL,0
/NUMBER,0
/PNUM,MAT,0
ET,1,SHELL181
KEYOPT,1,1,0
KEYOPT,1,3,2
ET,2,BEAM44
!* 膜材料
MPTEMP,,,,,,,,
MPTEMP,1,0
MPDATA,EX,1,,15e9
MPDATA,PRXY,1,,0.3
MPDATA,DENS,1,,0.1/0.0003
MPDATA,BETA,1,,0.05
!*  膜厚度
RMORE, , , ,
RMORE
RMORE, ,
/PREP7
RECTNG,-10,10,-10,10,
TYPE,   1
MAT,       1
REAL,       1
ESYS,       0
SECNUM,
!*定义网格密度
LESIZE,ALL,0.5, , , ,1, , ,1,
MSHAPE,1,2D
MSHKEY,0
AMESH, 1
ALLSEL,ALL
/GO
SFA,1,1,PRES,400
DK,1, , , ,0,ALL, , , , , ,
DK,2, , , ,0,ALL, , , , , ,
DK,3, , , ,0,ALL, , , , , ,
DK,4, , , ,0,ALL, , , , , ,
finish
   /solu
   antype,static
   nropt,full, ,on
   nlgeom,on
   pstr,on        ! prestress analysis
   sstif,on
   NSUBST,20,
   AUTOTS,on
   TIME,1
   LUMPM,0
   EQSLV, , ,0,
   PRECISION,0
   MSAVE,0
   PIVCHECK,1
   ematwrite,yes
   OUTRES,ERASE
   OUTRES,ALL,ALL
   solve
   fini
 楼主| 发表于 2013-2-18 22:21:12 | 显示全部楼层 来自 北京
出现的错误为
计算到最后不收敛,如下图
发表于 2013-2-23 14:12:37 | 显示全部楼层 来自 湖北武汉
查看不收敛的原因,以及与数值计算收敛性方面的相关问题楼主应该了解一下。
如约束是否足够、载荷步长是否足够或者时间步长是否过大等等。
二楼提示的错误信息为模型约束不足,产生刚体位移
GMT+8, 2024-9-23 21:32 , Processed in 0.025552 second(s), 10 queries , Gzip On, MemCache On.
