010-AMESim与Simulink联合仿真在舵机可靠性研究中的应用.pdf 011-AMESim环境下EHA模型的建立与分析.pdf 012-DDV作动器余度数字伺服系统工程设计与实现.pdf DDV作动器余度数字伺服系统工程设计与实现
夏立群
(西北工业大学自动化学院, 陕西西安 710072)
Engineering Design and Real ization of Redundant Digital Servo System for DDV Actuator
Xia Liqun
(Department of Automatic Cont rol , Northwestern Polytechnical University , Xi’an 710072 , China)
摘 要: 介绍一种直接驱动阀(DDV) 式作动器的余度数字式伺服系统设计与实现,描述了系统的余度配置、
设计思想及组成,建立了DDV 作动器的结构参数化模型及数字伺服回路的模型,并进行了仿真,分析了作动
器动静态特性、采样频率及监控器的设计性能。最后,采用快速原型实时仿真,对余度数字式伺服系统完成了
的性能试验验证,结果表明系统性能令人满意。
关键词: 直接驱动阀; 余度作动器; 数字伺服系统; 快速原型
中图分类号: V2491122 文献标识码: A
Abstract : An engineering design and realization of redundant digital servo system for direct drive valve (DDV)
actuator is presented. The DDV servo actuator is a new generation of elect ro2hydraulic redundant actuator ,
which has been used in many advanced aircraft . The redundant digital servo system int roduced in this paper
has been applied in an advanced t raining plane , and accomplished it s preliminary flight test s. The redundancy
level of servo system for DDV actuator and it s design concept are described. A simulation model oriented
st ructure parameter of DDV actuator is built , and so does the discrete model of redundant digital servo system.
A simulation is carried out to analyze the performances of DDV actuator , including static and dynamic charac2
teristics , sample f requency , and characteristics of monitor. In order to verify the performance of DDV actua2
tor , the redundant digital servo system is tested in a new way —rapid prototyping based on real2time SIMU2
L IN K/ xPC simulation , the result s show that the performance of the presented system is satisfied.
Key words : DDV ; redundant actuator ; digital servo system; rapid prototyping
