- 2013-3-14
函数:
db_add_t_nod_res_by_type( <num>, <rtid>, <rcid>, <layerids>, <nids>, <csys_type>, <cid>, <results> )
在帮助文档里,各参数的解释如下:
Input: | | | INTEGER | <num> | Number of nodes/results input. | INTEGER | <rtid> | Existing result type ID. | INTEGER | <rcid> | Existing result case ID. | INTEGER ARRAY | <layerids> | (num) sized array of layer ID for the result at each node. | INTEGER ARRAY | <nids> | (num) sized array of node IDs. | INTEGER ARRAY | <csys_type> | (num) sized array of coordinate system types where: -1=Unknown, 0=Global, 1=Nodal, 2=Element, 3=User, 4=Material, 5=Ply, 6=On Edge, 7=On Curve, 8=Data Dependent. | INTEGER ARRAY | <cid> | (num) sized array of CIDs (csys_type=3). | REAL ARRAY | <results> | (num,6) sized array of tensor results at each node/layer. | Output: | | | INTEGER | <Return Value> | This function returns a value of 0 when executed successfully and a non zero value to indicate a change in status or an error. | 但我不明白nids与cid是什么意思,怎么用啊?解释也看不懂 |
