我用Abaqus 做复合材料,看到手册里说,Gauss积分在壳的表面没有积分点,而Simpson 却有,这怎么理解啊?
这是手册里的原话:
Using Simpson's ruleBy default, Simpson's rule will be used for the shell sectionintegration. The default number of section points is five for a homogeneoussection and three in each layer for a composite section. Simpson's integration rule should be used if results output on theshell surfaces or transverse shear stress at the interface between two layersof a composite shell is required and must be used for heat transfer and coupledtemperature-displacement shell elements. Using Gauss quadrature If you use Gauss quadrature for the shellsection integration, the default number of section points is three for a homogeneous section and two ineach layer for a composite section. In Gauss quadrature there are no sectionpoints on the shell surfaces; therefore, Gauss quadrature should be used only in caseswhere results on the shell surfaces are not required. Gauss quadrature cannot be used for heattransfer and coupled temperature-displacement shell elements.
没有看到,关于壳体的数值积分的资料啊? 为什么复合材料每层壳单元的Gauss积分,表面没有Gauss积分点啊?
