- 46
- 2007-4-28
发表于 2013-9-18 16:41:00
来自 河北廊坊
我根据自己的理解,给出一个例子吧,原来的程序来自网络,嵌套的是自己修改的
不用嵌套函数的例子
- function [] = GUI_16()
- % Demonstrate display & change a slider's position & limits with edit boxes
- % This is an extension of GUI_13. Slide the slider and it's position will
- % be shown in the editbox. Enter a valid number in the editbox and the
- % slider will be moved to that position. If the number entered is outside
- % the range of the slider, the number will be reset. The range of the
- % slider will be shown in two editboxes on either side of the slider. The
- % user may change the range of the slider, as long as valid entries are
- % made.
- % Suggested exercise: Notice that any number (>min) is acceptable for the
- % max range number, and that when max is chosen such that max < value,
- % value is set equal to max. Modify the code to restrict max>=value. Do
- % similarly for the min.
- % Author: Matt Fig
- % Date: 7/15/2009
- S.fh = figure('units','pixels',...
- 'position',[300 300 390 100],...
- 'menubar','none',...
- 'name','GUI_16',...
- 'numbertitle','off',...
- 'resize','off');
- S.sl = uicontrol('style','slide',...
- 'unit','pix',...
- 'position',[60 10 270 30],...
- 'min',1,'max',100,'val',50);
- S.ed(1) = uicontrol('style','edit',...
- 'unit','pix',...
- 'position',[10 10 40 30],...
- 'fontsize',12,...
- 'string','1'); % Displays the min.
- S.ed(2) = uicontrol('style','edit',...
- 'unit','pix',...
- 'position',[60 50 270 30],...
- 'fontsize',16,...
- 'string','50'); % Displays the value.
- S.ed(3) = uicontrol('style','edit',...
- 'unit','pix',...
- 'position',[340 10 40 30],...
- 'fontsize',12,...
- 'string','100'); % Displays the max.
- set([S.ed(:);S.sl],'call',{@sl_call,S}); % Shared Callback.
- function [] = sl_call(varargin)
- % Callback for the edit box and slider.
- [h,S] = varargin{[1,3]}; % Get calling handle and structure.
- SL = get(S.sl,{'min','value','max'}); % Get the slider's info.
- E = str2double(get(h,'string')); % Numerical edit string.
- switch h % Who called?
- case S.ed(1)
- if E <= SL{2}
- set(S.sl,'min',E) % E is less than current value.
- elseif E < SL{3}
- set(S.sl,'val',E,'min',E) % E is less than max value.
- set(S.ed(2),'string',E) % Set the current display.
- else
- set(h,'string',SL{1}) % Reset the value.
- end
- case S.ed(2)
- if E >= SL{1} && E <= SL{3}
- set(S.sl,'value',E) % E falls within range of slider.
- else
- set(h,'string',SL{2}) % User tried to set slider out of range.
- end
- case S.ed(3)
- if E >= SL{2}
- set(S.sl,'max',E) % E is less than current value.
- elseif E > SL{1}
- set(S.sl,'val',E,'max',E) % E is less than max value.
- else
- set(h,'string',SL{3}) % Reset the value.
- end
- case S.sl
- set(S.ed(2),'string',SL{2}) % Set edit to current slider.
- otherwise
- % Do nothing
- end
复制代码 用嵌套函数的例子- function [] = GUI_16()
- % made.
- % Date: 7/15/2009
- 'resize','off');
- 'unit','pix',...
- 'unit','pix',...
- 'fontsize',12,...
- 'unit','pix',...
- 'fontsize',16,...
- 'unit','pix',...
- 'fontsize',12,...
- set([S.ed(:);S.sl],'call',@sl_call); % Shared Callback.
- function [] = sl_call(h,~)
- % [h,S] = varargin{[1,3]}; % Get calling handle and structure.
- case S.ed(1)
- if E <= SL{2}
- elseif E < SL{3}
- else
- end
- case S.ed(2)
- else
- end
- case S.ed(3)
- if E >= SL{2}
- elseif E > SL{1}
- else
- end
- case S.sl
- otherwise
- % Do nothing
- end
- end
- end
复制代码 |
