- 44
- 2005-3-18
*原文和相关软件下载连接请见http://hillyuan.blogspot.jp/2013 ... 261-in-mingw64.html
There is detailed description here http://mechanicalhacks.wordpress ... on-64-bit-windows/. But it doesnot works well, at least for ccx2.6.1. Here are some complemetation
1. Build ARPACK.
Modify ARmake.inc at follows
1) home="your current ARPACK home";
2) PLAT=anything you like. It would be appended in your library name.
3) Change the DIRS as
DIRS = (UTILdir) (SRCdir)
4) Make sure file second.f, which would in standard LAPACK library, in folder UTIL is not in your compile list.
5) RANLIB = touch
2. Build spooles
Following modifictions
1) Modify line 9 of SPOOLES.2.2/Tree/src/MakeGlobalLib from drawTree.c to draw.c
2) Modify line 204 of SPOOLES.2.2/MT/src/QRfactorMT.c from
tids[myid]=0;
to memset(&tids[myid], 0, sizeof(pthread_t) );
3) Modify Make.inc
THREAD_LIBS= -lpthread
4) Modify makefile
uncomment
# cd MT ; make lib
in make lib option
3. Build Calculix
1) Add #include "pthread.h" into file CalculiX.h
2) Modify Makefile as follows
・ Indicate where library of spooles, ARAPCK, BLAS and Lapack in in include in your LIBS, just like
DIR=../../../../solver/SPOOLES.2.2
BLASDIR = ../../../../solver/lapack-3.4.2
LIBDIR=/c/mingw64/x86_64-w64-mingw32/lib
LIBS = \
$(DIR)/MT/src/spoolesMT.a \
$(DIR)/spooles.a \
../../../../solver/ARPACK/libarpack_WIN64.a \
$(BLASDIR)/liblapack.a $(BLASDIR)/librefblas.a \
$(LIBDIR)/libpthread.a \
$(LIBDIR)/libm.a
Then just make it. That's all!
