- 2012-7-11
发表于 2013-11-20 14:25:01
来自 北京
here is the VUMAT for Isotropic Hardening:- C
- C Coding for Isotropic Hardening Plasticity VUMAT
- C
- SUBROUTINE VUMAT(
- C Read only -
- 1 NBLOCK, NDIR, NSHR, NSTATEV, NFIELDV, NPROPS, LANNEAL,
- 2 STEPTIME, TOTALTIME, DT, CMNAME, COORDMP, CHARLENGTH,
- 3 PROPS, DENSITY, STRAININC, RELSPININC,
- 4 TEMPOLD, STRETCHOLD, DEFGRADOLD, FIELDOLD,
- 5 STRESSOLD, STATEOLD, ENERINTERNOLD, ENERINELASOLD,
- 6 TEMPNEW, STRETCHNEW, DEFGRADNEW, FIELDNEW,
- C Write only -
- 7 STRESSNEW, STATENEW, ENERINTERNNEW, ENERINELASNEW)
- C
- INCLUDE 'VABA_PARAM.INC'
- C
- DIMENSION PROPS(NPROPS), DENSITY(NBLOCK), COORDMP(NBLOCK),
- 1 CHARLENGTH(NBLOCK), STRAININC(NBLOCK, NDIR+NSHR),
- 2 RELSPININC(NBLOCK, NSHR), TEMPOLD(NBLOCK),
- 3 STRETCHOLD(NBLOCK, NDIR+NSHR),DEFGRADOLD(NBLOCK,NDIR+NSHR+NSHR),
- 4 FIELDOLD(NBLOCK, NFIELDV), STRESSOLD(NBLOCK, NDIR+NSHR),
- 5 STATEOLD(NBLOCK, NSTATEV), ENERINTERNOLD(NBLOCK),
- 6 ENERINELASOLD(NBLOCK), TEMPNEW(NBLOCK),
- 7 STRETCHNEW(NBLOCK, NDIR+NSHR),DEFGRADNEW(NBLOCK,NDIR+NSHR+NSHR),
- 8 FIELDNEW(NBLOCK, NFIELDV), STRESSNEW(NBLOCK,NDIR+NSHR),
- 9 STATENEW(NBLOCK, NSTATEV), ENERINTERNNEW(NBLOCK),
- 1 ENERINELASNEW(NBLOCK)
- CHARACTER*80 CMNAME
- C LOCAL ARRAYS
- C ----------------------------------------------------------------
- C EELAS - ELASTIC STRAINS
- C EPLAS - PLASTIC STRAINS
- C FLOW - DIRECTION OF PLASTIC FLOW
- C
- DIMENSION EELAS(6),EPLAS(6),FLOW(6), HARD(3)
- C
- PARAMETER(ZERO=0.D0, ONE=1.D0, TWO=2.D0, THREE=3.D0, SIX=6.D0,
- 1 ENUMAX=.4999D0, NEWTON=10, TOLER=1.0D-6,HALF=0.5D0)
- C UMAT FOR ISOTROPIC ELASTICITY AND ISOTROPIC MISES PLASTICITY
- C CANNOT BE USED FOR PLANE STRESS
- C PROPS(1) - E
- C PROPS(2) - NU
- C PROPS(3..) - SYIELD AN HARDENING DATA
- C CALLS UHARD FOR CURVE OF YIELD STRESS VS. PLASTIC STRAIN
- C
- C ELASTIC PROPERTIES
- C
- EMOD=PROPS(1)
- ENU=MIN(PROPS(2), ENUMAX)
- EBULK3=EMOD/(ONE-TWO*ENU)
- EG2=EMOD/(ONE+ENU)
- EG=EG2/TWO
- EG3=THREE*EG
- ELAM=(EBULK3-EG2)/THREE
- NVALUE=NPROPS/2-1
- C
- C CALCULATE PREDICTOR STRESS AND ELASTIC STRAIN
- C
- IF ( STEPTIME .EQ. ZERO ) THEN
- DO K = 1, NBLOCK
- TRACE = STRAININC(K,1) + STRAININC(K,2) + STRAININC(K,3)
- STRESSNEW(K,1) = STRESSOLD(K,1)
- * + EG2 * STRAININC(K,1) + ELAM * TRACE
- STRESSNEW(K,2) = STRESSOLD(K,2)
- * + EG2 * STRAININC(K,2) + ELAM * TRACE
- STRESSNEW(K,3) = STRESSOLD(K,3)
- * + EG2 * STRAININC(K,3) + ELAM * TRACE
- STRESSNEW(K,4)=STRESSOLD(K,4) + EG2 * STRAININC(K,4)
- IF ( NSHR .GT. 1 ) THEN
- STRESSNEW(K,5)=STRESSOLD(K,5) + EG2 * STRAININC(K,5)
- STRESSNEW(K,6)=STRESSOLD(K,6) + EG2 * STRAININC(K,6)
- END IF
- END DO
- ELSE
- C
- C111111111111
- C
- DO K = 1, NBLOCK
- C
- END IF
- C
- SMISES=(STRESSNEW(K,1)-STRESSNEW(K,2))**2 +
- 1 (STRESSNEW(K,2)-STRESSNEW(K,3))**2 +
- 2 (STRESSNEW(K,3)-STRESSNEW(K,1))**2
- DO 90 K1=NDIR+1,NDIR+NSHR
- SMISES=SMISES+SIX*STRESSNEW(K,K1)**2
- 90 CONTINUE
- SMISES=SQRT(SMISES/TWO)
- C
- C RECOVER ELASTIC AND PLASTIC STRAINS AND ROTATE FORWARD
- C ALSO RECOVER EQUIVALENT PLASTIC STRAIN
- C
- C CALL ROTSIG(STATEOLD(K,1), DROT, EELAS, 2, NDIR, NSHR)
- C CALL ROTSIG(STATEOLD(K,1+NDIR+NSHR), DROT, EPLAS, 2, NDIR, NSHR)
- DO K1=1, NDIR+NSHR
- EELAS(K1)=STATEOLD(K,K1)
- EPLAS(K1)=STATEOLD(K,K1+NDIR+NSHR)
- END DO
- EQPLAS=STATEOLD(K,1+2*(NDIR+NSHR))!!!
- C
- C GET YIELD STRESS FROM THE SPECIFIED HARDENING CURVE
- C
- CALL VUHARD(SYIEL0, HARD, EQPLAS, EQPLASRT,TOTALTIME,DT,TEMP,
- 1 DTEMP,NOEL,NPT,LAYER,KSPT,KSTEP,KINC,CMNAME,
- 2 NUMFIELDV,NVALUE,PROPS(3))
- C
- C DETERMINE IF ACTIVELY YIELDING
- C
- IF (SMISES.GT.(ONE+TOLER)*SYIEL0) THEN
- C
- C ACTIVELY YIELDING
- C SEPARATE THE HYDROSTATIC FROM THE DEVIATORIC STRESS
- C CALCULATE THE FLOW DIRECTION
- C
- SHYDRO=(STRESSNEW(K,1)+STRESSNEW(K,2)+STRESSNEW(K,3))/THREE
- DO K1=1,NDIR
- FLOW(K1)=(STRESSNEW(K,K1)-SHYDRO)/SMISES
- END DO
- DO K1=NDIR+1,NDIR+NSHR
- FLOW(K1)=STRESSNEW(K,K1)/SMISES
- END DO
- C
- C SOLVE FOR EQUIVALENT VON MISES STRESS
- C AND EQUIVALENT PLASTIC STRAIN INCREMENT USING NEWTON ITERATION
- C
- SYIELD=SYIEL0
- DEQPL=ZERO
- DO KEWTON=1, NEWTON
- RHS=SMISES-EG3*DEQPL-SYIELD
- DEQPL=DEQPL+RHS/(EG3+HARD(1))
- CALL VUHARD(SYIELD,HARD,EQPLAS+DEQPL,EQPLASRT,TOTALTIME,DT,TEMP,
- 1 DTEMP,NOEL,NPT,LAYER,KSPT,KSTEP,KINC,CMNAME,NUMFIELDV,
- 2 NVALUE,PROPS(3))
- IF(ABS(RHS).LT.TOLER*SYIEL0) GOTO 10
- END DO
- C
- C WRITE WARNING MESSAGE TO THE .MSG FILE
- C
- WRITE(7,2) NEWTON
- 2 FORMAT(//,30X,'***WARNING - PLASTICITY ALGORITHM DID NOT',
- 1 'CONVERGE AFTER ',I3,' ITERATIONS')
- 10 CONTINUE
- C
- C UPDATE STRESS, ELASTIC AND PLASTIC STRAINS AND
- C EQUIVALENT PLASTIC STRAIN
- C
- DO K1=1,NDIR
- STRESSNEW(K,K1)=FLOW(K1)*SYIELD+SHYDRO
- EPLAS(K1)=EPLAS(K1)+THREE/TWO*FLOW(K1)*DEQPL
- EELAS(K1)=EELAS(K1)-THREE/TWO*FLOW(K1)*DEQPL
- END DO
- EPLAS(K1)=EPLAS(K1)+THREE*FLOW(K1)*DEQPL
- EELAS(K1)=EELAS(K1)-THREE*FLOW(K1)*DEQPL
- END DO
- EQPLAS=EQPLAS+DEQPL
- C
- C CALCULATE PLASTIC DISSIPATION
- C
- SPD=DEQPL*(SYIEL0+SYIELD)/TWO
- ENDIF
- C
- C STORE ELASTIC AND (EQUIVALENT) PLASTIC STRAINS
- C IN STATE VARIABLE ARRAY
- C
- STATENEW(K,K1)=EELAS(K1)
- STATENEW(K,K1+NDIR+NSHR)=EPLAS(K1)
- END DO
- STATENEW(K,1+2*(NDIR+NSHR)) = STATEOLD(K,1+2*(NDIR+NSHR)) + DEQPL
- C
- C UPDATE THE SPECIFIC INTERNAL ENERGY -
- C
- IF ( NSHR .EQ. 1 ) THEN
- STRESSPOWER = HALF * (
- * ( STRESSOLD(K,1) + STRESSNEW(K,1) ) * STRAININC(K,1) +
- * ( STRESSOLD(K,2) + STRESSNEW(K,2) ) * STRAININC(K,2) +
- * ( STRESSOLD(K,3) + STRESSNEW(K,3) ) * STRAININC(K,3) ) +
- * ( STRESSOLD(K,4) + STRESSNEW(K,4) ) * STRAININC(K,4)
- ELSE
- * ( STRESSOLD(K,4) + STRESSNEW(K,4) ) * STRAININC(K,4) +
- * ( STRESSOLD(K,5) + STRESSNEW(K,5) ) * STRAININC(K,5) +
- * ( STRESSOLD(K,6) + STRESSNEW(K,6) ) * STRAININC(K,6)
- END IF
- ENERINTERNNEW(K) = ENERINTERNOLD(K) + STRESSPOWER / DENSITY(K)
- C
- C UPDATE THE DISSIPATED INELASTIC SPECIFIC ENERGY -
- C
- PLASTICWORKINC = HALF * ( SYIEL0 + SYIELD ) * DEQPL
- ENERINELASNEW(K) = ENERINELASOLD(K) + PLASTICWORKINC / DENSITY(K)
- ENDDO
- END IF
- C
- RETURN
- END
- SUBROUTINE VUHARD(SYIELD,HARD,EQPLAS,EQPLASRT,TIME,DTIME,TEMP,
- 2 NUMFIELDV, NVALUE,TABLE)
- DIMENSION HARD(3)
- C
- DIMENSION TABLE(2, NVALUE)
- C
- PARAMETER(ZERO=0.D0)
- C
- C SET YIELD STRESS TO LAST VALUE OF TABLE, HARDENING TO ZERO
- C
- SYIELD=TABLE(1, NVALUE)
- HARD(1)=ZERO
- C
- C IF MORE THAN ONE ENTRY, SEARCH TABLE
- C
- IF(NVALUE.GT.1) THEN
- DO K1=1, NVALUE-1
- EQPL1=TABLE(2,K1+1)
- IF(EQPLAS.LT.EQPL1) THEN
- EQPL0=TABLE(2, K1)
- IF(EQPL1.LE.EQPL0) THEN
- WRITE(7, 1)
- 1 FORMAT(//, 30X, '***ERROR - PLASTIC STRAIN MUST BE ',
- 1 'ENTERED IN ASCENDING ORDER')
- CALL EXIT
- ENDIF
- C
- C CURRENT YIELD STRESS AND HARDENING
- C
- DEQPL=EQPL1-EQPL0
- SYIEL0=TABLE(1, K1)
- SYIEL1=TABLE(1, K1+1)
- DSYIEL=SYIEL1-SYIEL0
- HARD(1)=DSYIEL/DEQPL
- SYIELD=SYIEL0+(EQPLAS-EQPL0)*HARD(1)
- GOTO 10
- ENDIF
- END DO
- 10 CONTINUE
- ENDIF
- RETURN
- END
复制代码 |
