- 2012-4-16
我按照帮助文档中section print关键字的定义方法,定义输出某截面上的力和力矩(SOF,SOM),输出了dat文件
但是数据是保存在“job名.dat"这个文件中,并且以下面这样的形式保存的,这样处理数据很麻烦:INCREMENT 1 SUMMARY
TIME INCREMENT COMPLETED 1.406E-04, FRACTION OF STEP COMPLETED 1.406E-04
STEP TIME COMPLETED 1.406E-04, TOTAL TIME COMPLETED 1.406E-04
S E C T I O N O U T P U T-------------------------------每输出一步都有这个说明存在
SECTION NAME NA
SURFACE NAME ASSEMBLY_SURF-1
SYSTEM OF COORDINATES GLOBAL
NOTE: THE ABOVE SYSTEM OF COORDINATES IS MEANINGFUL ONLY FOR THE SOF AND SOM VARIABLES.
NOTE: SOCF IS ALWAYS REPORTED IN THE GLOBAL COORDINATE SYSTEM. IF THE DOT PRODUCT OF SOF
AND SOM IS NOT EQUAL TO ZERO, CENTROID OF THE SECTION IS REPORTED AS SOCF, AND SOM
IS NOT EQUAL TO THE CROSS PRODUCT OF SOCF AND SOF.
THE FOLLOWING TABLES ARE PRINTED
SOMM SOM1 SOM2 SOM3 SOFM SOF1 SOF2 SOF3
20.32 4.378 -19.82 -1.078 3.9690E-02 0.000 -2.1560E-03 3.9632E-02
INCREMENT 2 SUMMARY
TIME INCREMENT COMPLETED 1.406E-04, FRACTION OF STEP COMPLETED 2.812E-04
STEP TIME COMPLETED 2.812E-04, TOTAL TIME COMPLETED 2.812E-04
怎样以这样的形式输出结果呢??求帮助啊,谢谢
求帮助!!!谢谢啦
下面是我的定义
cutting surface定义:
*Surface, type=cutting surface, name=Surf-1
500,1,1,0,1,0
section print 输出定义:
*section print, name=NA, surface=surf-1,frequency=1
SOM,SOF
