/title, tongweidou
/nopr
/VIEW,1,1,1,1
/VUP,1,Z
/SHOW,win32c ! use /SHOW,x11c for Unix
/CONT,1,18
! *** Problem parameters
! Ferromagnetic plate:
lp=0.15 ! widen, m
hp=1 ! height, m
eszp=1 ! element size, m
sigp=6.66e6 ! conductivity, S/m
mu_fer=200 ! relative permeability
k=50 ! thermal conductivity, W/m_C
h=100 ! convection coefficient, W/(m^2_C)
! Coil:
ri=0.23 ! inner radius, m
ro=0.23 ! outer radius, m
hc=1 ! height, m
d=0.028 ! distance between the coil and the plate,m
eszc=1 ! element size, m
frq=50 ! frequency, Hz
I=1e5 ! rms coil current, A
mu_coil=1 ! relative permeability
! Air box:
la=0.5 ! length, m
ha1=0.05 ! lower height, m
ha2=0.35 ! upper height, m
esza=1 ! element size, m
mu_air=1 ! relative permeability
sigc=2e-8 ! conductivity, S/m
Tamb=70 ! ambient temperature,C
/com, !实体元件
/com, *** Eddy current analysis
/com,
/PREP7
et,1,236,1 ! AZ-VOLT - ferromagnetic plate
et,2,236,1,,,,1 ! AZ-VOLT (no eddy currents) - coil
et,3,236 ! AZ - air
et,4,236
et,5,236
/PREP7
blc4,0,0,0.128,0.128,1
blc4,0,0,0.103,0.103,1
VSEL,S,,,1
VSEL,A,,,2
CM,volum,VOLU
ALLSEL,ALL
VSBV,volum,2 ! coil
blc4,0,0,0.075,0.075,1 ! plate
!block,0,lp/2,0,lp/2,0,lp/2 ! plate
!cylinder,ri,ro,hp+d,hp+d+hc,0,1 ! coil
block,0,0.25,0,0.25,-0.05,0.35 ! air
vovlap,all
numcmp,all
mp,murx,1,mu_fer
mp,rsvx,1,1/sigp
mp,murx,2,mu_coil
mp,rsvx,2,sigc
mp,murx,3,mu_air
type,1
mat,1
esize,eszp
vmesh,1
type,2
mat,2
esize,eszc
vmesh,2
esha,1
type,3
mat,3
esize,esza
vmesh,3
asel,s,,,11
nsla,s,1
cp,1,volt,all
f,ndnext(0),amps,I*sqrt(2) ! rms
asel,s,,,12
nsla,s,1
d,all,volt,0
nsel,all
asel,s,,,3
asel,a,,,5
nsla,s,1
d,all,volt,0
nsel,all
nsel,s,ext
d,all,az,0 ! Flux-parallel magnetic BC
nsel,all
allsel
fini
/SOLU
antyp,harm
harf,,frq
solve
fini
/POST1
set,1,1
esel,s,mat,,1 ! select the plate
POWERH ! calculate rms power loss
plve,jt,,,,vect,elem,on ! plot eddy currents (real part)
set,1,1,,1
plve,jt,,,,vect,elem,on ! plot eddy currents (imag part)
alls
fini
/com,
/com, Ansys computed power loss = %Pavg*4% Watts
/com,
/com, *** Thermal analysis
/com,
/PREP7
ddele,all,az
vsel,s,volu,,1
eslv
et,1,90
LDREAD,hgen
vsel,inve
vclear,all
alls
etdele,2,3
mp,kxx,1,k
nsel,s,ext
sf,all,conv,h,Tamb
nsel,all
fini
/SOLU
anty,static
solve
fini
/POST1
set,1,1
plnsol,temp
nsort,temp
*get,minTemp,sort,,min
*get,maxTemp,sort,,max
avTemp=(minTemp+maxTemp)/2
/com,
/com, Average temperature of the plate = %avTemp% (C)
/com,
fini
试试对不对大牛们 |
