查看: 44|回复: 2
[后处理] Optistruck解算问题求助大神~~
发表于 2014-3-26 20:33:22 | 显示全部楼层 |阅读模式 来自 浙江
初次接触Hypermesh,根据教程做出一模型,解算提示内容如下:求错误原因,附模型,请大神修改,谢谢!
**                          OptiStruct 10.0                           **
**                  Design and Optimization Software                  **
**                   from Altair Engineering, Inc.                    **
**          Windows XP Professional  SP3 (Build 2600)  SHALL          **
**        4 CPU:  AMD Athlon(tm) II X4 641 Quad-Core Processor        **
**                        CPU speed  2800 MHz                         **
**                     1648 MB RAM,  4095 MB swap                     **
** Build tag: 0466938_5333O00_Ci3242M-000      4000                   **
**  COPYRIGHT (C) 1996-2009                 Altair Engineering, Inc.  **
** All Rights Reserved.  Copyright notice does not imply publication. **
** Contains trade secrets of Altair Engineering, Inc.                 **
** Decompilation or disassembly of this software strictly prohibited. **
*** OptiStruct defaults set from:
   install config file: D:\Altair\hw10.0/hwsolvers/hwsolver.cfg
*** ERROR # 1237 ***
CQUAD4 element number 1 references
        a missing or invalid property number 1.
CQUAD4 element number 2 references
        a missing or invalid property number 2.
CQUAD4 element number 3 references
        a missing or invalid property number 3.
CQUAD4 element number 4 references
        a missing or invalid property number 4.
CQUAD4 element number 5 references
        a missing or invalid property number 5.
CQUAD4 element number 7 references
        a missing or invalid property number 7.
CQUAD4 element number 8 references
        a missing or invalid property number 8.
CQUAD4 element number 9 references
        a missing or invalid property number 9.
CQUAD4 element number 10 references
        a missing or invalid property number 10.
CQUAD4 element number 11 references
        a missing or invalid property number 11.
CQUAD4 element number 12 references
        a missing or invalid property number 12.
CQUAD4 element number 13 references
        a missing or invalid property number 13.
CQUAD4 element number 14 references
        a missing or invalid property number 14.
CQUAD4 element number 15 references
        a missing or invalid property number 15.
CQUAD4 element number 16 references
        a missing or invalid property number 16.
CQUAD4 element number 17 references
        a missing or invalid property number 17.
CQUAD4 element number 18 references
        a missing or invalid property number 18.
CQUAD4 element number 19 references
        a missing or invalid property number 19.
CQUAD4 element number 20 references
        a missing or invalid property number 20.
*** More of ERROR messages # 1237 were suppressed...
Error # 14 appeared total of 4800 times.
*** ERROR # 14 ***
       4800 errors found in the input data.
RESOURCE USAGE INFORMATION
MAXIMUM MEMORY USED                                        32 MB
MAXIMUM DISK SPACE USED                                     0 MB
COMPUTE TIME INFORMATION
EXECUTION STARTED                         Wed Mar 26 20:33:27 2014
EXECUTION COMPLETED                       Wed Mar 26 20:33:29 2014
ELAPSED TIME                                         00:00:01
CPU TIME                                             00:00:01
*** PROGRAM STOPPED: FATAL ERROR(s) ENCOUNTERED.
                        ***** END OF REPORT *****
For Useful OptiStruct Tips and Tricks, go to the URL:
http://www.altairhyperworks.com/tips.aspx
Following error/warning messages appeared too many times
and were suppressed:
    1237
Total of 4781 repeat error message(s) were suppressed.
To see more messages use "MSGLMT" control card in the data or config file.
There were 4800 error messages during input processing.
  The first message is repeated below:
 楼主| 发表于 2014-3-26 20:36:09 | 显示全部楼层 来自 浙江
教程文件太大,详见网址:http://wenku.baidu.com/link?url= ... bTn4FHXPzcDOaGvfdG_
发表于 2014-3-26 21:13:55 | 显示全部楼层 来自 湖南长沙
模型中的2D网格没删掉
GMT+8, 2024-10-5 11:24 , Processed in 0.026992 second(s), 9 queries , Gzip On, MemCache On.
