查看: 60|回复: 2
[ADAMS CAR, Chassis, Engine] Car仿真时报错The identifier ……
发表于 2014-4-1 07:15:54 | 显示全部楼层 |阅读模式 来自 北京
悬赏10仿真币未解决
ERROR:  A syntax error is in this function expression.
ERROR:     Argument            : FUNCTION
ERROR:     Statement           : VARIABLE/262
ERROR:     Line number         : 13508
ERROR:  The function expression indicated contains at least one error.
ERROR:  Description   : The identifier '._POWERTRAIN.TOTAL_AXLE_TORQUE' was found where an ADAMS id was expected.
ERROR:
ERROR:  Function text : "MAX(-ABS(VARVAL([[._POWERTRAIN.TOTAL_AXLE_TORQUE]])),MIN(ABS(VARVAL._LAV_8X8_POWERTRAIN.TOTAL_AXLE_TORQUE)),"
ERROR:                  (The element at or immediately after the error is
ERROR:                   enclosed in double brackets '[[' and ']]'.)
上面是Car仿真时的ERROR,没有找到原因,请高手帮助一下呀!!!!
 楼主| 发表于 2014-4-1 09:10:38 | 显示全部楼层 来自 北京
已经解决了
回复
 楼主| 发表于 2014-4-1 09:11:20 | 显示全部楼层 来自 北京
VARVAL([[._POWERTRAIN.TOTAL_AXLE_TORQUE]输入错了,换一个就好了
回复
GMT+8, 2024-11-2 11:25 , Processed in 0.026934 second(s), 9 queries , Gzip On, MemCache On.
