我知道步骤啊,我现在初步怀疑是建模的时候出现问题,你能帮我看一下吗?
以下是我的命令流:
/NOPR ! Suppress printing of UNDO process
/PMACRO ! Echo following commands to log
FINISH ! Make sure we are at BEGIN level
/CLEAR,NOSTART ! Clear model since no SAVE found
! WE SUGGEST YOU REMOVE THIS LINE AND THE FOLLOWING STARTUP LINES
/input,menust,tmp,'',,,,,,,,,,,,,,,,1
/GRA,POWER
/GST,ON
/PLO,INFO,3
/GRO,CURL,ON
/CPLANE,1
/REPLOT,RESIZE
WPSTYLE,,,,,,,,0
/NOPR
KEYW,PR_SET,1
KEYW,PR_STRUC,0
KEYW,PR_THERM,1
KEYW,PR_FLUID,0
KEYW,PR_ELMAG,0
KEYW,MAGNOD,0
KEYW,MAGEDG,0
KEYW,MAGHFE,0
KEYW,MAGELC,0
KEYW,PR_MULTI,0
KEYW,PR_CFD,0
/GO
/PREP7
ET,1,PLANE55
MPTEMP,,300,800,1400,2000,2600,3253
MPDATA,KXX,1,,40,16,10.1,9.4,8.6,5.4
MPDATA,C,1,,797,973,1113,1329,1540,1660
MPDATA,ENTH,1,,8.56E7,2.46E9,5.89E9,9.825E9,1.427E10,1.97E10
MPDATA,DENS,1,,3980,3980,3980,3980,3980,3980
MPDATA,KXX,2,,395,395,325,295,230,170
MPDATA,C,2,,380,437,550,737,968,1272
MPDATA,ENTH,2,,8.56E7,2.058E9,5.54E9,1.137E10,2.012E10,3.328E10
MPDATA,DENS,2,,8930,8930,8930,8930,8930,8930
MPDATA,KXX,3,,0.55,0.7,15,45,68,198
MPDATA,C,3,,3400,3600,3800,4000,4240,4380
MPDATA,ENTH,3,,4.51E8,9.438E9,2.467E10,4.467E10,6.48E10,8.896E10
MPDATA,DENS,3,,1200,1200,1200,1200,1200,1200
RECTNG,0,0.0005,0,0.00006,
RECTNG,0,0.0005,0.00006,0.000065,
RECTNG,0,0.0005,0.000065,0.000195,
K,13,0.0002,0.000065,,
K,14,0.0003,6.5e-005,,
LSTR, 13, 14
FLST,2,3,5,ORDE,2
FITEM,2,1
FITEM,2,-3
AGLUE,P51X
NUMCMP,LINE
NUMCMP,AREA
CM,_Y,AREA
ASEL, , , , 1
CM,_Y1,AREA
CMSEL,S,_Y
CMSEL,S,_Y1
AATT, 3, , 1, 0,
CMSEL,S,_Y
CMDELE,_Y
CMDELE,_Y1
CM,_Y,AREA
ASEL, , , , 2
CM,_Y1,AREA
CMSEL,S,_Y
CMSEL,S,_Y1
AATT, 2, , 1, 0,
CMSEL,S,_Y
CMDELE,_Y
CMDELE,_Y1
CM,_Y,AREA
ASEL, , , , 3
CM,_Y1,AREA
CMSEL,S,_Y
CMSEL,S,_Y1
AATT, 1, , 1, 0,
CMSEL,S,_Y
CMDELE,_Y
CMDELE,_Y1
/PNUM,KP,0
/PNUM,LINE,1
/PNUM,AREA,0
/PNUM,VOLU,0
/PNUM,NODE,0
/PNUM,TABN,0
/PNUM,SVAL,0
/NUMBER,0
/PNUM,ELEM,0
/REPLOT
LPLOT
FLST,5,11,4,ORDE,2
FITEM,5,1
FITEM,5,-11
CM,_Y,LINE
LSEL, , , ,P51X
CM,_Y1,LINE
CMSEL,,_Y
LESIZE,_Y1,2e-6, , , , , , ,1
MSHKEY,0
FLST,5,3,5,ORDE,2
FITEM,5,1
FITEM,5,-3
CM,_Y,AREA
ASEL, , , ,P51X
CM,_Y1,AREA
CHKMSH,'AREA'
CMSEL,S,_Y
AMESH,_Y1
CMDELE,_Y
CMDELE,_Y1
CMDELE,_Y2
)/GOP ! Resume printing after UNDO process
)! We suggest a save at this point
