查看: 200|回复: 1
deform仿真切削出错,求解!!!
发表于 2014-5-7 10:41:42 | 显示全部楼层 |阅读模式 来自 华南理工大学
  FREE SURFACE TREATMENT
SFTC : Fatal error in RREALLOC
        An error occured when re-allocating dynamic
        memory. The size that was requested was not
        allocated.
        Size Requested  : 0 bytes
        Old Size        : 0 bytes
        Total allocated : 4420196 bytes
        The above error should not have happened
        If this error occurs repeatedly,
        Please contact SFTC and report the conditions
        under which it occurs.
发表于 2014-5-16 10:33:33 | 显示全部楼层 来自 湖北武汉
请问你是用deform10.2做的仿真吗?这个版本不太稳定,经常会有这种问题,这不是你设置的问题。个人感觉用deform6.0做仿真比较稳定
GMT+8, 2026-1-7 04:44 , Processed in 0.022080 second(s), 11 queries , Gzip On, MemCache On.
