- 2013-5-20
因为换电脑,软件选择升级,6.12升级至6.13-1,原来可以计算的一个屈曲模型,现在无法提交,软件报错,求是版本问题还是?附上CAE模型和报错信息:The executable standard.exe aborted with system error code 1073741819.Please check the .dat, .msg, and .sta files for error messages if the files exist. If there are no error messages and you cannot resolve the problem, please run the command "abaqus job=support information=support" to report and save your system information. Use the same command to run Abaqus that you used when the problem occurred. Please contact your local Abaqus support office and send them the input file, the file support.log which you just created, the executable name, and the error code.
确定temp文件地址中无汉字,部分explict模型可以计算
