- 2011-1-3
如图所示的结构,角钢小架子,在hypermesh里面调好方向如下图所示:
然后导入ansys就成这样了:
明显有问题啊! HM只是按照node往外倒模型,但是ansys梁单元的方向是由latte命令定义的,参照点还是kp,这是不是算是bug啊,各位大牛们??
------------------------------------------------------------------ 下面是HM到出的命令流------------------
/PREP7
*IF,_CDRDOFF,EQ,1,THEN !if solid model was read in
_CDRDOFF= !reset flag, numoffs already performed
*ELSE !offset database for the following FE model
NUMOFF,NODE, 26
NUMOFF,ELEM, 18
NUMOFF,MAT, 1
NUMOFF,SECN, 1
NUMOFF,TYPE, 1
*ENDIF
NBLOCK,6,SOLID
(3i8,6e16.9)
4 0 0 2.273736754E-13 -4.19930757E-12 300.0
9 0 0 -150.0 -4.19752070E-12 300.0
5 0 0 -800.0 -4.18977761E-12 300.0
6 0 0 -637.5 -4.19171338E-12 300.0
16 0 0 -637.5 -1.33158173E-15 -300.0
7 0 0 -475.0 -4.19364915E-12 300.0
8 0 0 -312.5 -4.19558493E-12 300.0
14 0 0 -800.0 3.839645423E-29 -300.0
19 0 0 -150.0 -5.74687545E-15 -300.0
12 0 0 -800.0 6.917279580E-15 0.0
11 0 0 -800.0 1.056406715E-14 150.0
3 0 0 -150.0 -4.19752070E-12 300.0
10 0 0 -800.0 1.421085472E-14 300.0
15 0 0 -800.0 0.0 -300.0
17 0 0 -475.0 -2.80334630E-15 -300.0
13 0 0 -800.0 3.270492013E-15 -150.0
18 0 0 -312.5 -4.27511087E-15 -300.0
21 0 0 -1.13686838E-13 -7.10542736E-15 -300.0
20 0 0 -150.0 -5.74687545E-15 -300.0
23 0 0 -150.0 -5.89750471E-13 150.0
25 0 0 -150.0 -5.89750471E-13 -150.0
24 0 0 -150.0 -5.89750471E-13 -2.84217094E-14
26 0 0 -150.0 -5.89750471E-13 -300.0
22 0 0 -150.0 -5.89750471E-13 300.0
N,R5.3,LOC, -1,
MPTEMP,1, 0.0
MP,EX ,1, 200000.0
MP,PRXY,1, 0.3
ET,1,188
SECTYPE,1,BEAM, L, 188
SECDATA,63.0,63.0,8.0,8.0
SECOFFSET, ORIGIN
SECCONTROLS,0.0,0.0,0.0,0.0
TYPE, 1 $ MAT, 1 $ REAL, 0 $ SECNUM, 1
EBLOCK,19,SOLID,
(19i8)
1 1 0 1 0 0 0 0 2 0 18 25 26
1 1 0 1 0 0 0 0 2 0 17 24 25
1 1 0 1 0 0 0 0 2 0 16 23 24
1 1 0 1 0 0 0 0 2 0 15 22 23
1 1 0 1 0 0 0 0 2 0 14 20 21
1 1 0 1 0 0 0 0 2 0 13 18 19
1 1 0 1 0 0 0 0 2 0 12 17 18
1 1 0 1 0 0 0 0 2 0 11 16 17
1 1 0 1 0 0 0 0 2 0 10 15 16
1 1 0 1 0 0 0 0 2 0 6 10 11
1 1 0 1 0 0 0 0 2 0 7 11 12
1 1 0 1 0 0 0 0 2 0 8 12 13
1 1 0 1 0 0 0 0 2 0 9 13 14
1 1 0 1 0 0 0 0 2 0 5 8 9
1 1 0 1 0 0 0 0 2 0 4 7 8
1 1 0 1 0 0 0 0 2 0 3 6 7
1 1 0 1 0 0 0 0 2 0 2 5 6
1 1 0 1 0 0 0 0 2 0 1 3 4
-1
CM, HM_188, ELEM
ESEL, NONE
ESEL, ALL
LSCLEAR, ALL
LSWRITE,1
FINISH
