查看: 126|回复: 1
[接触分析] 在ANSYS接触分析中KEYOPT(9) = 4与KEYOPT(9) = 6区别到底在哪?
发表于 2014-6-26 23:22:49 | 显示全部楼层 |阅读模式 来自 福建
具体问题一:contact surface penetration (CNOF)与contact offset (CNOF) 是同一个概念么?
具体问题二:KEYOPT(9) = 4忽略the penetration due to geometry,但考虑the gap due to geometry;而KEYOPT(9) = 6即忽略the penetration due to geometry又忽略the gap due to geometry?
以下是ANSYS14.5帮助原文摘录:
1.To ramp the defined contact surface penetration (CNOF), but ignore the penetration due to geometry, set KEYOPT(9) = 4. This option works if initial penetration is detected for certain contact definitions (KEYOPT(12) = 0, 1, 2, 3, or 6).
2.To ramp the defined contact offset (CNOF) but ignore the penetration or gap due to geometry, set KEYOPT(9) = 6. This option works as long as the contact is detected within the pinball region (near-field or closed contact). For a bonded contact definition with KEYOPT(12) = 4 or 5, setting KEYOPT(9) = 4 is equivalent to setting KEYOPT(9) = 6.
发表于 2014-7-3 10:36:32 | 显示全部楼层 来自 北京
谢谢分享
GMT+8, 2024-4-28 20:04 , Processed in 0.026232 second(s), 11 queries , Gzip On, MemCache On.
