查看: 45|回复: 0
[基础知识] 两零件合并和固定的问题
发表于 2014-7-5 16:34:46 | 显示全部楼层 |阅读模式 来自 浙江宁波
Adams初学者,请大家赐教。如图所示,问题一:由于从PROE导入Adams的零件太多,part1和part2在Marker点处添加固定副后,仿真运行时两个零件还是脱离(Marker 怎么设置也不行);问题二:考虑另一种方法是将两个零件合并,在Bodies-booleans里选合并,出现错误The I and J markers of a joint or primitive joint must belong to different parts of the same model to which the joint or primitive joint belongs不知道怎么解决了
GMT+8, 2024-11-2 09:29 , Processed in 0.025624 second(s), 10 queries , Gzip On, MemCache On.
