- 2014-10-31
** OptiStruct 12.0 **
** Design and Optimization Software **
** from Altair Engineering, Inc. **
** Windows XP Professional SP3 (Build 2600) 20131128-1607 **
** 2 CPU: Intel(R) Core(TM)2 Duo CPU P8400 @ 2.26GHz **
** CPU speed 2250 MHz **
** 1494 MB RAM, 4095 MB swap **
** Build tag: 0654688_5333120_Ci32RBUH12M:77575-000 4000000004001 **
** COPYRIGHT (C) 1996-2013 Altair Engineering, Inc. **
** All Rights Reserved. Copyright notice does not imply publication. **
** Contains trade secrets of Altair Engineering, Inc. **
** Decompilation or disassembly of this software strictly prohibited. **
*** OptiStruct defaults set from:
install config file: C:\Program Files\Altair\12.0\/hwsolvers/hwsolver.cfg.
NOTE # 9199
MSGLMT=BRIEF is active, following messages will be suppressed:
741 742 1935 1052 1305 1436 1437 1051 1931 1932 2010
Use MSGLMT=STRICT (e.g. in config file) to turn back full printing.
*** WARNING # 2303
MBD cards are present in the data, but there is no MBD subcases.
JOINTs, MBD loads and other MBD cards will be ignored.
*** Problem(s) found while reading line 816697 from file:
D:/My Documents/my_session/my_session-3.fem
"CTETRA 107581 0 52543 10902 10882 57297"
This line was interpreted as:
816697:CTETRA, 107581, 0, 52543, 10902, 10882, 57297
*** ERROR # 1000 *** in the input data:
Incorrect data in field # 3.
Expected INT > 0, found INTEGER (0).
*** Problem(s) found while reading line 816698 from file:
"CTETRA 107582 0 70535 29734 29735 29767"
