其实问题很简单,模型和施加的力都很简单。但是我调试很久都无法解决这个问题,希望有大侠可以帮帮忙。
一个橡胶密封圈,简化为二维模型,先第一步纵向压紧,然后第二步右侧施加力。但是第二步计算总是不收敛,出现过很多问题,我调试不出来了,希望有前辈可以解答一下。
附上我初始的代码,我后来调试过的代码由于依然没收敛,就不放上了。
在这里先谢过了。
- /PREP7
- *SET,L1,10e-3
- *SET,L2,12.675e-3
- *SET,L3,11.366e-3
- *SET,L5,2.616e-3
- *SET,L4,(L1-L5)/2
- *SET,L6,1.366e-3
- *SET,D,0.063e-3
- *SET,DC,1.708e-3
- *SET,DE1,0.205e-3
- *SET,DE2,0.339e-3
- *SET,E1,43e6
- *SET,v1,0.499
- *SET,C10,0.2e6
- *SET,C01,6e6
- *SET,dd,0.000279
- *SET,E2,210e9
- *SET,v2,0.29
- *SET,f,0.2
- *SET,LL,DC-D-L6
- K,1,-L1,-LL,,
- K,2,L1,-LL,,
- K,3,L1,L2-LL,,
- K,4,-L1,L2-LL,,
- K,5,-L1,L2+D,,
- K,6,-L5/2,L2+D,,
- K,7,-L5/2,L2+D+L6,,
- K,8,L5/2,L2+D+L6,,
- K,9,L5/2,L2+D,,
- K,10,L1,L2+D,,
- K,11,L1,L2+D+L3,,
- K,12,-L1,L2+D+L3,,
- K,13,0,L2+D+L6-DC/2,,
- L,1,2
- L,2,3
- L,3,4
- L,4,1
- L,5,6
- L,6,7
- L,7,8
- L,8,9
- L,9,10
- L,10,11
- L,11,12
- L,12,5
- A,1,2,3,4
- A,5,6,7,8,9,10,11,12
- CYL4,0,L2+D+L6-DC/2,DC/2
- aplot
- ET,1,PLANE183
- ET,2,PLANE183
- KEYOPT,1,1,0
- KEYOPT,1,3,2
- KEYOPT,1,6,1
- TB,HYPE,1,1,2,MOON
- TBTEMP,0
- TBDATA,,C10,C01,dd,,,
- MPTEMP,,,,,,,,
- MPTEMP,1,0
- MPDATA,EX,1,,E1
- MPDATA,PRXY,1,,v1
- MPTEMP,,,,,,,,
- MPTEMP,1,0
- MPDATA,EX,2,,E2
- MPDATA,PRXY,2,,v2
- TYPE, 1
- MAT, 1
- REAL,
- ESYS, 0
- SECNUM,
- FLST,2,1,5,ORDE,1
- FITEM,2,3
- AESIZE,P51X,0.0001,
- MSHAPE,0,2D
- MSHKEY,0
- CM,_Y,AREA
- ASEL, , , , 3
- CM,_Y1,AREA
- CHKMSH,'AREA'
- CMSEL,S,_Y
- AMESH,_Y1
- CMDELE,_Y
- CMDELE,_Y1
- CMDELE,_Y2
- aplot
- TYPE, 2
- MAT, 2
- REAL,
- ESYS, 0
- SECNUM,
- FLST,2,2,5,ORDE,2
- FITEM,2,1
- FITEM,2,-2
- AESIZE,P51X,0.001,
- FLST,5,2,5,ORDE,2
- FITEM,5,1
- FITEM,5,-2
- CM,_Y,AREA
- ASEL, , , ,P51X
- CM,_Y1,AREA
- CHKMSH,'AREA'
- CMSEL,S,_Y
- AMESH,_Y1
- CMDELE,_Y
- CMDELE,_Y1
- CMDELE,_Y2
- CM,_NODECM,NODE
- CM,_ELEMCM,ELEM
- CM,_KPCM,KP
- CM,_LINECM,LINE
- CM,_AREACM,AREA
- CM,_VOLUCM,VOLU
- /GSAV,cwz,gsav,,temp
- MP,MU,1,f
- MAT,1
- MP,EMIS,1,7.88860905221e-031
- R,3
- REAL,3
- ET,3,169
- ET,4,172
- R,3,,,1.0,0.1,0,
- RMORE,,,1.0E20,0.0,1.0,
- RMORE,0.0,0,1.0,,1.0,0.5
- RMORE,0,1.0,1.0,0.0,,1.0
- KEYOPT,4,3,0
- KEYOPT,4,4,0
- KEYOPT,4,5,1
- KEYOPT,4,7,0
- KEYOPT,4,8,0
- KEYOPT,4,9,0
- KEYOPT,4,10,2
- KEYOPT,4,11,0
- KEYOPT,4,12,0
- KEYOPT,4,2,0
- ! Generate the target surface
- LSEL,S,,,5
- LSEL,A,,,6
- LSEL,A,,,7
- CM,_TARGET,LINE
- TYPE,3
- NSLL,S,1
- ESLN,S,0
- ESURF
- CMSEL,S,_ELEMCM
- ! Generate the contact surface
- LSEL,S,,,13
- LSEL,A,,,14
- LSEL,A,,,15
- CM,_CONTACT,LINE
- TYPE,4
- NSLL,S,1
- ESLN,S,0
- ESURF
- ALLSEL
- ESEL,ALL
- ESEL,S,TYPE,,3
- ESEL,A,TYPE,,4
- ESEL,R,REAL,,3
- /PSYMB,ESYS,1
- /PNUM,TYPE,1
- /NUM,1
- EPLOT
- ESEL,ALL
- ESEL,S,TYPE,,3
- ESEL,A,TYPE,,4
- ESEL,R,REAL,,3
- CMSEL,A,_NODECM
- CMDEL,_NODECM
- CMSEL,A,_ELEMCM
- CMDEL,_ELEMCM
- CMSEL,S,_KPCM
- CMDEL,_KPCM
- CMSEL,S,_LINECM
- CMDEL,_LINECM
- CMSEL,S,_AREACM
- CMDEL,_AREACM
- CMSEL,S,_VOLUCM
- CMDEL,_VOLUCM
- /GRES,cwz,gsav
- CMDEL,_TARGET
- CMDEL,_CONTACT
- CM,_NODECM,NODE
- CM,_ELEMCM,ELEM
- CM,_KPCM,KP
- CM,_LINECM,LINE
- CM,_AREACM,AREA
- CM,_VOLUCM,VOLU
- MP,MU,1,0.2
- MAT,1
- R,4
- REAL,4
- ET,5,169
- ET,6,172
- KEYOPT,6,9,0
- KEYOPT,6,10,2
- R,4,
- RMORE,
- RMORE,,0
- RMORE,0
- LSEL,S,,,3
- CM,_TARGET,LINE
- TYPE,5
- NSLL,S,1
- ESLN,S,0
- ESURF
- CMSEL,S,_ELEMCM
- LSEL,S,,,15
- LSEL,A,,,16
- CM,_CONTACT,LINE
- TYPE,6
- NSLL,S,1
- ESLN,S,0
- ESURF
- ALLSEL
- ESEL,ALL
- ESEL,S,TYPE,,5
- ESEL,A,TYPE,,6
- ESEL,R,REAL,,4
- /PSYMB,ESYS,1
- /PNUM,TYPE,1
- /NUM,1
- EPLOT
- ESEL,ALL
- ESEL,S,TYPE,,5
- ESEL,A,TYPE,,6
- ESEL,R,REAL,,4
- CMSEL,A,_NODECM
- CMDEL,_NODECM
- CMSEL,A,_ELEMCM
- CMDEL,_ELEMCM
- CMSEL,S,_KPCM
- CMDEL,_KPCM
- CMSEL,S,_LINECM
- CMDEL,_LINECM
- CMSEL,S,_AREACM
- CMDEL,_AREACM
- CMSEL,S,_VOLUCM
- CMDEL,_VOLUCM
- /GRES,cwz,gsav
- CMDEL,_TARGET
- CMDEL,_CONTACT
- /MREP,EPLOT
- eplot
- FINISH
- /SOL
- ANTYPE,0
- NLGEOM,1
- NSUBST,120,100000,100
- OUTRES,ERASE
- OUTRES,ALL,1
- NCNV,2,0,0,0,0
- PRED,ON
- RESCONTRL,DEFINE,ALL,1,1
- TIME,1
- FLST,2,1,4,ORDE,1
- FITEM,2,1
- /GO
- DL,P51X, ,UX,
- FLST,2,1,4,ORDE,1
- FITEM,2,11
- /GO
- DL,P51X, ,ALL,
- FLST,2,1,4,ORDE,1
- FITEM,2,1
- /GO
- DL,P51X, ,UY,LL
- FINISH
- /POST1
- FINISH
- /SOL
- TIME,1
- AUTOTS,1
- NSUBST,50,100000,30,1
- KBC,0
- TSRES,ERASE
- PRED,ON
- LSWRITE,1,
- FLST,5,22,2,ORDE,4
- FITEM,5,892
- FITEM,5,-902
- FITEM,5,937
- FITEM,5,-947
- CM,_Y,ELEM
- ESEL, , , ,P51X
- CM,_Y1,ELEM
- CMSEL,S,_Y
- CMDELE,_Y
- /GO
- SFE,_Y1,1,PRES, ,6900000, , ,
- esel,all
- eplot
- TIME,2
- AUTOTS,1
- NSUBST,150,100000,100,1
- KBC,0
- TSRES,ERASE
- PRED,ON
- LSWRITE,2,
复制代码
