查看: 84|回复: 1
[ADAMS CAR, Chassis, Engine] 大家有做过整车空气弹簧悬架的仿真么?探讨一下吧!
发表于 2014-12-24 09:56:16 | 显示全部楼层 |阅读模式 来自 辽宁沈阳
大家有做过整车空气弹簧悬架的仿真么?探讨一下吧!需要注意什么?怎样调整参数?仿真问题方面的。
 楼主| 发表于 2014-12-24 10:20:34 | 显示全部楼层 来自 辽宁沈阳
ERROR:  The spline statement is missing the Y argument.
ERROR:     Statement           : SPLINE/925
ERROR:     Line number         : 10365
ERROR:     Statement           : SPLINE/926
ERROR:     Line number         : 10371
ERROR:  Errors in the Adams dataset prevent it from being loaded into the database.
---- START: ERROR ----
Attempt to read in model into AMD was unsuccessful
---- END: ERROR ----
command: string/4, string=constant_r_crc.xml
This command cannot be processed until a model has been defined.
command: preferences/solver=CXX
command: preferences/status=on
command: control/routine=abgTire::con901,func=user(901,79,93,99,1,2)
command: control/routine=abgTire::con901,func=user(901,83,94,100,1,4)
command: control/routine=abgTire::con901,func=user(901,88,102,108,1,6)
command: control/routine=abgTire::con901,func=user(901,92,103,109,1,8)
command: output/nosep
command: control/ routine=abgVDM::EventInit, function=user(4,1,7,1298,2,5,7,13)
command: control/ routine=abgVDM::EventRunAll, function=user(0)
command: !
command: stop
GMT+8, 2024-9-23 12:23 , Processed in 0.026949 second(s), 11 queries , Gzip On, MemCache On.
