*** WARNING *** CP = 7.203 TIME= 20:21:22
A reference heat flow value times the tolerance is used by the
Newton-Raphson method for checking convergence. The calculated
reference HT FLOW CONVERGENCE VALUE= 0 is less than a threshold. This
threshold defaults to 1.0e-6 or is specified as MINREF on the CNVTOL
command. Check results carefully.
