- 2015-1-12
命令流:
n
gen zone radcyl p0 (0,0,0) p1 (8,0,0) p2 (0,0,-8) p3 (0,8,0) &
p4 (8,0,-8) p5 (0,8,-8) p6 (8,8,0) p7 (8,8,-8) &
p8 (.3,0,0) p9 (0,.3,0) p10 (.3,0,-8) p11 (0,.3,-8) &
size 3 32 6 15 ratio 1 1 1 1.15 fill
gen zone radcyl p0 (0,0,-8) p1 (8,0,-8) p2 (0,0,-10) p3 (0,8,-8) &
p4 (8,0,-10) p5 (0,8,-10) p6 (8,8,-8) p7 (8,8,-10) &
p8 (.3,0,-8) p9 (0,.3,-8) p10 (.3,0,-10) p11 (0,.3,-10) &
size 3 8 6 15 ratio 1 1 1 1.15 fill
gen zone reflect dd 270 dip 90
gen zone reflect nor 0 1 0 ori 0 0 0
group clay
del range cyl end1 0 0 -8.05 end2 0 0 -6.95 radius 0.32 gro clay
gen zone cyl p0 (0,0,2) p1 (.3,0,2) p2 (0,0,1) p3 (0,.3,2) &
p4 (.3,0,1) p5 (0,.3,1) &
size 3 4 6
gen zone reflect dd 270 dip 90 range z 1 2
gen zone reflect nor 0 1 0 ori 0 0 0 range z 1 2
group pile_1 range z 1 2
ini z add -9.0 range group pile_1
model mohr range group clay
prop bulk 8.333e7 shear 3.846e7 coh 30000 fric 0 range group clay
model elas range group pile_1
prop bulk 8.333e7 shear 3.846e7 range group pile_1
ini dens 1230 range group clay
ini dens 1230 range group pile_1
fix z range z -10.1 -9.9
fix x range x -8.1 -7.9
fix x range x 7.9 8.1
fix y range y -8.1 -7.9
fix y range y 7.9 8.1
set grav 0 0 -10
ini szz 0. grad 0 0 12300. range z -10 0.
ini sxx 0. grad 0 0 5271.4 range z -10 0.
ini syy 0. grad 0 0 5271.4 range z -10 0.
hist unbal
solve
prop bulk 13.9e9 shear 10.4e9 range group pile_1
ini dens 2500 range group pile_1
solve
save pile_2.sav
ini state 0
ini xdis 0.0 ydis 0.0 zdis 0.0
apply nstress 4e6 range cyl end1 0 0 -8.05 end2 0 0 -7.95 radius 0.32 group clay
apply nstress 4e6 range cyl end1 0 0 -7.05 end2 0 0 -6.95 radius 0.32 group clay
apply nstress 4e6 range cyl end1 0 0 -8.05 end2 0 0 -6.95 radius 0.28 not &
cyl end1 0 0 -8.05 end2 0 0 -6.95 radius 0.32 group clay
hist id=3 gp zdis 0 0.2 0
pl hist 3
step 2000
rest pile_3.sav
del range cyl end1 0 0 -7.05 end2 0 0 -5.95 radius 0.32 gro clay
size 3 4 6
group pile_2 range z 1 2
ini z add -8.0 range group pile_2
model elas range group pile_2
prop bulk 13.9e9 shear 10.4e9 range group pile_2
ini dens 1230 range group pile_2
apply nstress 4e6 range cyl end1 0 0 -6.05 end2 0 0 -5.95 radius 0.32 group clay
apply nstress 4e6 range cyl end1 0 0 -7.05 end2 0 0 -5.95 radius 0.28 not &
cyl end1 0 0 -7.05 end2 0 0 -5.95 radius 0.32 group clay
pl hist 3
step 2000
save pile_4.sav
rest pile_4.sav
del range cyl end1 0 0 -6.05 end2 0 0 -4.95 radius 0.32 gro clay
size 3 4 6
group pile_3 range z 1 2
ini z add -7.0 range group pile_3
model elas range group pile_3
prop bulk 13.9e9 shear 10.4e9 range group pile_3
ini dens 1230 range group pile_3
apply nstress 4e6 range cyl end1 0 0 -5.05 end2 0 0 -4.95 radius 0.32 group clay
apply nstress 4e6 range cyl end1 0 0 -6.05 end2 0 0 -4.95 radius 0.28 not &
cyl end1 0 0 -6.05 end2 0 0 -4.95 radius 0.32 group clay
pl hist 3
step 2000
save pile_5.sav
rest pile_5.sav
del range cyl end1 0 0 -5.05 end2 0 0 -3.95 radius 0.32 gro clay
size 3 4 6
group pile_4 range z 1 2
ini z add -6.0 range group pile_4
model elas range group pile_4
prop bulk 13.9e9 shear 10.4e9 range group pile_4
ini dens 1230 range group pile_4
apply nstress 4e6 range cyl end1 0 0 -4.05 end2 0 0 -3.95 radius 0.32 group clay
apply nstress 4e6 range cyl end1 0 0 -5.05 end2 0 0 -3.95 radius 0.28 not &
cyl end1 0 0 -5.05 end2 0 0 -3.95 radius 0.32 group clay
pl hist 3
step 2000
save pile_6.sav
rest pile_6.sav
del range cyl end1 0 0 -4.05 end2 0 0 -2.95 radius 0.32 gro clay
size 3 4 6
group pile_5 range z 1 2
ini z add -5.0 range group pile_5
model elas range group pile_5
prop bulk 13.9e9 shear 10.4e9 range group pile_5
ini dens 1230 range group pile_5
apply nstress 4e6 range cyl end1 0 0 -3.05 end2 0 0 -2.95 radius 0.32 group clay
apply nstress 4e6 range cyl end1 0 0 -4.05 end2 0 0 -2.95 radius 0.28 not &
cyl end1 0 0 -4.05 end2 0 0 -2.95 radius 0.32 group clay
pl hist 3
step 1000
save pile_7.sav
rest pile_7.sav
del range cyl end1 0 0 -3.05 end2 0 0 -1.95 radius 0.32 gro clay
size 3 4 6
group pile_6 range z 1 2
ini z add -4.0 range group pile_6
model elas range group pile_6
prop bulk 13.9e9 shear 10.4e9 range group pile_6
ini dens 1230 range group pile_6
apply nstress 4e6 range cyl end1 0 0 -2.05 end2 0 0 -1.95 radius 0.32 group clay
apply nstress 4e6 range cyl end1 0 0 -3.05 end2 0 0 -1.95 radius 0.28 not &
cyl end1 0 0 -3.05 end2 0 0 -1.95 radius 0.32 group clay
pl hist 3
step 1000
save pile_8.sav
想要实现从土里起桩然后在桩土界面施加压力。模型能计算但是就是在利用flactotecplot后生成的文件在tecplot里面打开时出现 FE cell 17520 has bad index of 17972 |
