- 4
- 2008-4-29
发表于 2015-7-1 01:26:26
来自 美国
I do not know if it is a system bug, you work long enough in HM, you see lots of bugs.
I am not a HM developer, just using HM as a tool to prepare my model. So when there is an alternative way, I do not care about why this way does not work as long as there is other way to do it.
The beauty of HM is there is always multiple way to do one thing. Sure, extending is the easiest way to do what you want to do here.
If I were you, I would just cut the cylindrical surface with the edge of rib, and then create a surface using two parallel lines (edge of rib plate and cut edge on the cylindrical surface), and then toggle the shared edge. |
