查看: 68|回复: 2
ansys焊接分析出现错误,求指教!
发表于 2015-6-8 00:07:10 | 显示全部楼层 |阅读模式 来自 中国
本人新人,在计算过程中遇到一个问题,求各位前辈帮忙!激光焊模拟,在计算过程中出现 value=-833.33 is outside function range EXP,请问什么意思,该怎么解决,谢谢!
命令流如下:
/config,nres,60000
/prep7
ET,1,SOLID70
/prep7
mp,dens,1,4440
mptemp,1,20,100,200,300,400,500,
mptemp,7,600,700,800,1000,1200,1500,,,,
mpdata,kxx,1,1,6.8,7.4,8.7,9.8,10.3,11.8,
mpdata,kxx,1,7,13.3,14.8,16.3,19.3,22.3,26.8,,,,
mpdata,c,1,1,611,624,653,674,691,703,
mpdata,c,1,7,711,719.6,726.8,739.1,749.3,762,,,,
MPTEMP,,,,,,,,
MPTEMP,1,20
MPTEMP,2,100
MPTEMP,3,200
MPTEMP,4,300
MPTEMP,5,400
MPTEMP,6,500
MPTEMP,7,600
MPTEMP,8,700
MPTEMP,9,800
MPDE,EX,1
MPDE,EY,1
MPDE,EZ,1
MPDE,NUXY,1
MPDE,NUYZ,1
MPDE,NUXZ,1
MPDE,PRXY,1
MPDE,PRYZ,1
MPDE,PRXZ,1
MPDE,GXY,1
MPDE,GYZ,1
MPDE,GXZ,1
MPDATA,EX,1,,109E9
MPDATA,EX,1,,102E9
MPDATA,EX,1,,95E9
MPDATA,EX,1,,87E9
MPDATA,EX,1,,80E9
MPDATA,EX,1,,72E9
MPDATA,EX,1,,65E9
MPDATA,EX,1,,57E9
MPDATA,EX,1,,49E9
MPDATA,PRXY,1,,0.34
MPDATA,PRXY,1,,0.34
MPDATA,PRXY,1,,0.34
MPDATA,PRXY,1,,0.34
MPDATA,PRXY,1,,0.34
MPDATA,PRXY,1,,0.34
MPDATA,PRXY,1,,0.34
MPDATA,PRXY,1,,0.34
MPDATA,PRXY,1,,0.34
!model
BLOCK,0,0.001,0,0.12,-0.0015,0.0015
BLOCK,0.001,0.007,0,0.12,-0.0015,0.0015
block,0.007,0.015,0,0.12,-0.0015,0.0015
VGLUE,all
!***mesh weld line(2mm)
!y-direction along the weld direction
LESIZE,1, , ,480, , , , ,1
LESIZE,3, , ,480, , , , ,1
LESIZE,6, , ,480, , , , ,1
LESIZE,8, , ,480, , , , ,1
!x-direction
LESIZE,2, , ,4, , , , ,1
LESIZE,4, , ,4,, , , ,1
LESIZE,5, , ,4, , , , ,1
LESIZE,7, , ,4, , , , ,1
!z-direction
LESIZE,10, , ,10, , , , ,1
LESIZE,9, , ,10, , , , ,1
LESIZE,11, , ,10, , , , ,1
LESIZE,12, , ,10, , , , ,1
!heat affect zone
!x-direction
LESIZE,38, , ,12, , , , ,1
LESIZE,39, , ,12, , , , ,1
LESIZE,37, , ,12, , , , ,1
LESIZE,40, , ,12, , , , ,1
!y-direction
LESIZE,15, , ,480, , , , ,1
LESIZE,18, , ,480, , , , ,1
!z-direction
LESIZE,22, , ,10, , , , ,1
LESIZE,23, , ,10, , , , ,1
! the third part
!x-direction
LESIZE,42, , ,4, , , , ,1
LESIZE,43, , ,4, , , , ,1
LESIZE,41, , ,4, , , , ,1
LESIZE,44, , ,4, , , , ,1
!y-direction
LESIZE,15, , ,480,, , , ,1
LESIZE,18, , ,480,, , , ,1
LESIZE,30, , ,480,, , , ,1
LESIZE,27, , ,480,, , , ,1
!z-direction
LESIZE,34, , ,10,, , , ,1
LESIZE,35, , ,10,, , , ,1
!mesh
MSHAPE,0,3D
MSHKEY,1
vmesh,1
vmesh,4
vmesh,5
!solve
!sol
*DIM,conv,TABLE,9,1,1,temp, ,
*SET,CONV(0,1,1) , 0
*SET,CONV(1,0,1) , 20
*SET,CONV(1,1,1) , 50
*SET,CONV(2,0,1) , 300
*SET,CONV(2,1,1) , 50
*SET,CONV(3,0,1) , 600
*SET,CONV(3,1,1) , 50
*SET,CONV(4,0,1) , 750
*SET,CONV(4,1,1) , 50
*SET,CONV(5,0,1) , 900
*SET,CONV(5,1,1) , 50
*SET,CONV(6,0,1) , 1200
*SET,CONV(6,1,1) , 50
*SET,CONV(7,0,1) , 1500
*SET,CONV(7,1,1) , 50
*SET,CONV(8,0,1) , 1800
*SET,CONV(8,1,1) , 50
*SET,CONV(9,0,1) , 2000
*SET,CONV(9,1,1) , 50
*DIM,conv1,TABLE,9,1,1,temp, ,
*SET,CONV1(0,1,1) , 0
*SET,CONV1(1,0,1) , 20
*SET,CONV1(1,1,1) , 50
*SET,CONV1(2,0,1) , 300
*SET,CONV1(2,1,1) , 50
*SET,CONV1(3,0,1) , 600
*SET,CONV1(3,1,1) , 50
*SET,CONV1(4,0,1) , 750
*SET,CONV1(4,1,1) , 50
*SET,CONV1(5,0,1) , 900
*SET,CONV1(5,1,1) , 50
*SET,CONV1(6,0,1) , 1200
*SET,CONV1(6,1,1) , 50
*SET,CONV1(7,0,1) , 1500
*SET,CONV1(7,1,1) , 50
*SET,CONV1(8,0,1) , 1800
*SET,CONV1(8,1,1) , 50
*SET,CONV1(9,0,1) , 2000
*SET,CONV1(9,1,1) , 50
a=10e-3
a1=5e-3
b=0.3e-3
c=4.5e-3
c1=4e-3
e=2.72
p=4000
eff=0.85
pi=3.14
h=3e-3
r0=0.3e-3
f1=0.4
f2=0.25
f3=0.2
/sol
ANTYPE,4
TUNIF,20,
TREF,20,
IC,all,TEMP,20,
NSEL,s,LOC,z,0.0015
SF,all,CONV,%CONV% ,20
allsel,all
NSEL,s,LOC,z,-0.0015
allsel,all
j=0
*do,i,0.01,0.11,0.00025
        j=j+0.015
        local,11,1,0,i,
        nsel,s,loc,x,0,0.005
        nsel,r,loc,z,-0.0015,0.0015
        nplot
        csys,0
        *get,nmax,node,,num,max
        *get,nmin,node,,num,min
                *do,ei,nmin,nmax
                        *if,nsel(ei),eq,1,then
                        *get,elx,node,ei,loc,x
                        *get,ely,node,ei,loc,y
                        *get,elz,node,ei,loc,z
     *if,elz,ge,-0.0015,and,elz,le,-0.0012,then
      ely1=ely-i
      elz1=elz+0.0015
      !_____________________
      qa1=6*sqrt(3.0)*p
      qa2=qa1/(a*b*c*pi*sqrt(pi))
      qa3=exp(-3*elx**2/c**2)
      qa4=qa3*exp(-3*ely1**2/a**2)
      qa5=qa4*exp(-3*elz1**2/b**2)
      qm1=eff*qa2*qa5*f1
      q10=3.15*p
      q20=q10/(pi*h*r0**2)
      q30=exp(-3*elx**2/r0**2)
      q40=q30*exp(-3*ely1**2/r0**2)
      qm2=eff*q20*q40*f2
      qm3=qm1+qm2
       BF,ei,HGEN,qm3
      *elseif,elz,ge,-0.0012,and,elz,le,0.0012,then
      ely1=ely-i
      q10=3.15*p
      qm2=eff*q20*q40*f2
      qm3=qm2
       BF,ei,HGEN,qm3
      *elseif,elz,ge,0.0012,and,elz,le,0.0015,then
      ely1=ely-i
      elz1=elz-0.0015
      qa1=6*sqrt(3.0)*p
      qa2=qa1/(a1*b*c1*pi*sqrt(pi))
      qa3=exp(-3*elx**2/c1**2)
      qa4=qa3*exp(-3*ely1**2/a1**2)
      qm1=eff*qa2*qa5*f3
      q10=3.15*p
      qm2=eff*q20*q40*f2
      qm3=qm1+qm2
       BF,ei,HGEN,qm3
*endif
                        *endif
                *enddo
        TIME,j
        LNSRCH,1
        TIMINT,1
        !TINTP,0.007, , ,1, , ,
        AUTOTS,1
        DELTIM,0.03
        outres,nsol,all
        KBC,1
        TSRES,ERASE
        allsel,all
        solve
        BFDELE,ALL,HGEN
        BF,ALL,HGEN,0
        allsel,all
*ENDDO
!!cooling
allsel,all
BFDELE,ALL,HGEN
BF,ALL,HGEN,0
SFDELE,all,CONV
NSEL,s,LOC,z,0.0015
SF,all,CONV,%CONV1% ,20
allsel,all
sf,all,conv,%CONV1% ,20
allsel,all
NSEL,S,LOC,y,0
allsel,all
NSEL,S,LOC,y,0.12
allsel,all
NSEL,s,LOC,x,0.015
allsel,all
time,9
deltim,0.2
!outres,all,last
OUTRES,NSOL,all,
autots,on
!kbc,0
kbc,1
solve
time,200
deltim,2
!outres,all,last
OUTRES,NSOL,all,
autots,on
kbc,1
solve
time,300
deltim,5
!outres,all,last
OUTRES,NSOL,all,
autots,on
kbc,1
solve
time,500
deltim,10
!outres,all,last
OUTRES,NSOL,all,
autots,on
kbc,1
solve
save
finish
 楼主| 发表于 2015-6-8 23:22:05 | 显示全部楼层 来自 中国
有没有人知道这个错误什么意思?
发表于 2015-6-12 16:17:29 | 显示全部楼层 来自 广东广州
做过高斯热源的 apdl
GMT+8, 2024-9-22 07:25 , Processed in 0.026474 second(s), 12 queries , Gzip On, MemCache On.
