查看: 312|回复: 2
[其他] AVL EXCITE缩减时调用Abaqus求解出现错误信息,求助!
发表于 2015-9-9 20:14:49 | 显示全部楼层 |阅读模式 来自 北京
inp文件如下:
*HEADING
Excite FEA Condensation
*INCLUDE, INPUT=Crankshaft.inp
** ------ STEP natural frequency extraction
** ------ with constraint retained static dofs
*STEP
*FREQUENCY, EIGENSOLVER=LANCZOS, NORMALIZATION=MASS
40, 0.,
*BOUNDARY, OP=MOD
200000,1,6,0.
200001,1,6,0.
1001001,1,6,0.
1001002,1,6,0.
1001003,1,6,0.
1001004,1,6,0.
1001005,1,6,0.
1001006,1,6,0.
1001007,1,6,0.
1001008,1,6,0.
1001009,1,6,0.
1001010,1,6,0.
1001011,1,6,0.
1001012,1,6,0.
1001013,1,6,0.
1001014,1,6,0.
1001015,1,6,0.
1001016,1,6,0.
1001017,1,6,0.
1001018,1,6,0.
1001019,1,6,0.
1001020,1,6,0.
1001021,1,6,0.
1001022,1,6,0.
1001023,1,6,0.
1001024,1,6,0.
1001025,1,6,0.
1001026,1,6,0.
1001027,1,6,0.
1001028,1,6,0.
1001029,1,6,0.
1001030,1,6,0.
1001031,1,6,0.
1001032,1,6,0.
1001033,1,6,0.
1001034,1,6,0.
1001035,1,6,0.
1001036,1,6,0.
1001037,1,6,0.
1001038,1,6,0.
1001039,1,6,0.
1001040,1,6,0.
1001041,1,6,0.
1001042,1,6,0.
1001043,1,6,0.
1001044,1,6,0.
1001045,1,6,0.
1001046,1,6,0.
1001047,1,6,0.
1001048,1,6,0.
*END STEP
** ------ STEP substructure generate
*STEP
*SUBSTRUCTURE GENERATE, TYPE=Z1, OVERWRITE, MASS MATRIX=YES,
RECOVERY MATRIX=NO, FLEXIBLE BODY=X
*RETAINED NODAL DOFS, SORTED=YES
200000,1,6
200001,1,6
1001001,1,6
1001002,1,6
1001003,1,6
1001004,1,6
1001005,1,6
1001006,1,6
1001007,1,6
1001008,1,6
1001009,1,6
1001010,1,6
1001011,1,6
1001012,1,6
1001013,1,6
1001014,1,6
1001015,1,6
1001016,1,6
1001017,1,6
1001018,1,6
1001019,1,6
1001020,1,6
1001021,1,6
1001022,1,6
1001023,1,6
1001024,1,6
1001025,1,6
1001026,1,6
1001027,1,6
1001028,1,6
1001029,1,6
1001030,1,6
1001031,1,6
1001032,1,6
1001033,1,6
1001034,1,6
1001035,1,6
1001036,1,6
1001037,1,6
1001038,1,6
1001039,1,6
1001040,1,6
1001041,1,6
1001042,1,6
1001043,1,6
1001044,1,6
1001045,1,6
1001046,1,6
1001047,1,6
1001048,1,6
*SELECT EIGENMODES, GENERATE
1,40,
*END STEP
** SIGN: 3v6Q7pkxCTSr+Q==
求解时出现下面的错误
***ERROR: in keyword *SUBSTRUCTUREGENERATE, file "Crankshaft_cond.inp", line
           71: The following option is currently not supported in a model
           defined in terms of an assembly of part instances: *SUBSTRUCTURE
           GENERATE
***NOTE: DUE TO AN INPUT ERROR THE ANALYSIS PRE-PROCESSOR HAS BEEN UNABLE TO
          INTERPRET SOME DATA.  SUBSEQUENT ERRORS MAY BE CAUSED BY THIS OMISSION
***ERROR: in keyword *BOUNDARY, file "Crankshaft_cond.inp", line 12: Unknown
           assembly id 200000.
           assembly id 200001.
           assembly id 1001001.
多谢大家了!!
发表于 2015-9-11 20:23:40 | 显示全部楼层 来自 浙江温州
错误信息很明显,有限元模型中不存在编号为200000、200001、1001001 节点。请检查有限元模型。
GMT+8, 2026-1-2 19:59 , Processed in 0.024965 second(s), 12 queries , Gzip On, MemCache On.
