查看: 293|回复: 1
[动态分析] ABAQUS/explicit热力耦合
发表于 2015-10-28 22:49:51 | 显示全部楼层 |阅读模式 来自 广东广州
小弟ABAQUS新手( status file)中显示错误:
***ERROR: Capacitance is not defined for the isothermal rigid bodies with the
          reference nodes listed below, but the temperature degrees of freedom
          are not constrained at the reference node. Abaqus/Explicit now
          requires isothermal rigid bodies to have a non-zero capacitance
          unless temperature degrees of freedom are constrained with the
          *BOUNDARY option. Nodes that are part of an isothermal rigid body do
          not require capacitance individually, but the rigid body as a whole
          must possess capacitance unless constraints are used. To remedy this
          error, either add temperature constraints to the reference nodes
          with the *BOUNDARY option or add capacitance using the *HEATCAP
          option, whichever is appropriate to obtain the desired response. A
          node set named "ErrNodeIsoThermBodyNoCap" containing the problematic
          reference nodes is created for use in Abaqus/Viewer to help the user
          locate the error and modify the input definition.
发表于 2020-6-28 20:41:57 | 显示全部楼层 来自 中国
刀具是要刚体约束吧
GMT+8, 2024-10-1 23:49 , Processed in 0.026151 second(s), 12 queries , Gzip On, MemCache On.
