查看: 235|回复: 6
[材料模型] How to set up the material failure for beam element?
发表于 2016-4-19 17:23:45 | 显示全部楼层 |阅读模式 来自 辽宁
1 Introduction
      Few days ago, Brother. You asked a question, and this's the description: He wants to  make the material failure of beam element, but whatever he've done, it didn't work. He used the material 03, *MAT_Plastic_Kinematic, and gave the failure criterion by FS. Then he tried to add the erosion by *MAT_ADD_EROSION, but nothing happened.
     At this opportunity, I make the simple test and try to make some conclusion.
2 Preparation
     The model is set up as a cantilever beam subjected to uniaxial tension as below:
     The basic element section and material input parameters:
     And i make four cases:
    They are related to the following Keywords:
    1, FS is the EPS failure for MAT03;
    2, A_erosion means *MAT_ADD_EROSION;
    3, BeamIP can be found in *DATABASE_EXTENT_BINARY.
    Read the Manuals for more details.
3 Results and conclusions
    Firstly, the VM-ES and EPS of CASE 1 are shown:
   We can see that the VM-ES is 636.7Mpa and EPS is 0.0368 at the last state, and this is why i make the CASE 2, 3 and 4.
   Secondly, the four cases comparision as follow:
   So, we can make some preliminary conclusions:
   1, MAT03 can be used for HL beam(and Truss, elemform=1,3), and the FS is available;
   2, BeamIP only affects the plot of the beam stress and strain;
   3, *MAT_ADD_EROSION is worked for beam element types 1 and 11.
P.S.  Time is short, so the content above is very simple, and if you've found any mistake, don't hesitate to tell me.
        Thank you very much.
The input K file of CASE 4 as below:
发表于 2016-4-19 17:27:06 | 显示全部楼层 来自 江苏南京
我来赞一个
发表于 2016-4-19 17:28:06 来自手机 | 显示全部楼层 来自 山西太原
我来赞一个
发表于 2016-4-19 17:29:32 | 显示全部楼层 来自 湖南
赞一个,高手
发表于 2016-5-5 10:21:55 来自手机 | 显示全部楼层 来自 中国
虽然我看不懂 赞一个
发表于 2016-5-6 09:34:26 | 显示全部楼层 来自 江苏南京
学习了,*MAT_ADD_EROSION 对beam 单元还没有是试过,用过MAT03  FS是可以的,另外要想记录并在ls-prepost中显示beam积分点的结果必须要设置*DATABASE_EXTENT_BINARY中的BeamIP
发表于 2016-6-8 22:51:46 | 显示全部楼层 来自 江苏南京
真的老外做的?
GMT+8, 2024-6-3 23:04 , Processed in 0.040240 second(s), 18 queries , Gzip On, MemCache On.
