- 2024-10-14
发表于 2024-10-14 21:25:31
来自 广东广州
请教大佬们,计算时出现下面这个,结果动画里轴和基体脱离,轴飞出来了咋弄呀
Information (Code 8420013)
New joint jacobians were calculated at least for one joint in step 1044.
Number of total joint jacobian updates is 9.
Current Model loop number is 1.
For body GearShaft1 the target accuracy could not be reached.
Accuracy of joint forces: 1.00000E+00 / 1.00000E-02 (reached/target)
Highest deviations occur at Node/DOF: 231354/2, 231355/2, 231354/1
For body MB-Wall1 the target accuracy could not be reached.
Balance of forces: 8.27921E+04 / 3.28583E+03 (reached/target)
Accuracy of joint forces: 9.99998E-01 / 1.00000E-02 (reached/target)
Highest deviations occur at Node/DOF: 203402/1, 203402/2, 203422/1
Interrupted or ended loop unsuccessful after 114 iterations |
