- 2015-11-18
楼主 |
发表于 2016-11-29 20:50:50
来自 安徽合肥
;;;;;;;静力部分;;;;;;;
;;;;;;;模型网格建立;;;;;;;;
new
config dynamic gpextra 10 zextra 10
gen zone brick size 11 1 11
model mohr
prop bulk=12.5e9 shear=5.8e9 coh=11.7e9 fric=41
ini dens 1840
; Create three geogrid layers
sel geogrid id=1 range x=(0.0,8.0) z=(10.99, 11.01)
sel node init zpos add -7.5 range z=(10.99, 11.01)
sel geogrid id=2 range x=(0.0,8.0) z=(10.99, 11.01)
sel node init zpos add -4.5 range z=(10.99, 11.01)
sel geogrid id=3 range x=(0.0,8.0) z=(10.99, 11.01)
sel node init zpos add -1.5 range z=(10.99, 11.01)
sel node init ypos multiply 0.11111 range z=(10.99, 11.01)
sel geogrid prop iso=(22e9, 0.33) thick=3e-3 &
cs_sk=3.5e6 cs_scoh=11.7
sel geogrid prop cs_sfric=41
; Assign BCs and install soil in-situ stresses
fix z range z -.1,.1
fix x range x -.1,.1
fix x range x 10.9,11.1
fix y
set grav=9.81 ;large
set dyn=off
solv
