在做航空发动机叶片的模态分析时,打开科氏效应,结果,很快就把我的D的硬盘都要塞满了。都计算不是下去,不知道这个是什么原因,怎么解决。
提示:
*** WARNING *** CP = 114.453 TIME= 19:14:53
The Distributed Sparse Matrix Solver used by the Block Lanczos
eigensolver is currently running in the out-of-core memory mode. This
memory mode may provide significantly worse performance compared to
the in-core memory mode, depending on the amount of available system
memory and I/O speed. Please monitor the solver performance to ensure
that the large amount of I/O to the solver files does not create a
bottleneck for performance
