本人找了一个常刚度法编写的材料本构在UMAT 中加载,发现以下错误:
Error in job Job-2: THE OPTION *USER MATERIAL,TYPE=MECHANICAL COMPLETELY DEFINES THE MATERIAL BEHAVIOR. IT CAN NOT BE USED WITH AN OPTION THAT DEFINES PART OF A MATERIAL`S BEHAVIOR
Error in job Job-2: 60 elements have been defined with zero hour glass stiffness. You may use *hourglass stiffness or change the element type. The elements have been identified in element set ErrElemZeroHourGlassStiffness.
Error in job Job-2: A MATERIAL PROPERTY THAT IS NOT ALLOWED WITH A USER MATERIAL HAS BEEN SPECIFIED
Job Job-2: Analysis Input File Processor aborted due to errors.
Error in job Job-2: Analysis Input File Processor exited with an error.
Job Job-2 aborted due to errors.
是什么意思啊
