为何我运行这个inp文件出现报错呢?
报错内容如下:
There are 5 warning messages in the data (.dat) file. Please check the data file for possible errors in the input file.
The elements that have both displacements and temperatures as nodal variables are used in a pure explicit dynamic analysis. The temperature degrees of freedom will be ignored.
Boundary conditions are defined at the nodes contained in node set WarnNodeBcIntersectKinCon. In addition the nodes are also part of a surface involved in kinematic contact. The kinematic contact constraint will be overridden by the boundary conditions in case of a conflict. Penalty contact may be used instead.
