查看: 77|回复: 1
[土木] Abaqus中出现如下警告怎么处理
发表于 2019-11-23 11:04:40 | 显示全部楼层 |阅读模式 来自 河北
Abaqus中出现如下警告,出现零主元,这个怎么办,而且模型可以计算,这个警告对后面结果有什么影响吗?希望大神解答,谢谢
Solver problem. Zero pivot when processing D.O.F. 1 of 37 nodes. The nodes have been identified in node set WarnNodeSolvProbZeroPiv_1_1_1_1_1.
Solver problem. Zero pivot when processing D.O.F. 2 of 12 nodes. The nodes have been identified in node set WarnNodeSolvProbZeroPiv_2_1_1_1_1.
There are 9 unconnected regions in the model.
Solver problem. Zero pivot when processing D.O.F. 1 of 37 nodes. The nodes have been identified in node set WarnNodeSolvProbZeroPiv_1_2_1_1_1.
Solver problem. Zero pivot when processing D.O.F. 2 of 12 nodes. The nodes have been identified in node set WarnNodeSolvProbZeroPiv_2_2_1_1_1.
发表于 2019-11-23 15:26:22 | 显示全部楼层 来自 北京
只要能算,警告一般都可以忽略
GMT+8, 2024-10-2 10:33 , Processed in 0.069258 second(s), 12 queries , Gzip On, MemCache On.
