查看: 88|回复: 0
[警告错误信息] 错误代码1073740791,请问我出现了这个问题是由于什么啊
发表于 2020-5-5 23:14:28 | 显示全部楼层 |阅读模式 来自 山东
ERROR in job messaging system: Error in connection to analysis
Error in job shiyan: The executable standard.exe aborted with system error code 1073740791. Please check the .dat, .msg, and .sta files for error messages if the files exist.  If there are no error messages and you cannot resolve the problem, please run the command "abaqus job=support information=support" to report and save your system information.  Use the same command to run Abaqus that you used when the problem occurred.  Please contact your local Abaqus support office and send them the input file, the file support.log which you just created, the executable name, and the error code.
这几天被这个问题整的头都大了,但是就是找不到出现问题的地方,而且结果文件中也没有msg文件。
GMT+8, 2024-10-2 01:28 , Processed in 0.028735 second(s), 11 queries , Gzip On, MemCache On.
