查看: 60|回复: 2
[警告错误信息] 问下这个耦合定义有问题,一般怎么解决啊
发表于 2021-5-7 15:11:07 | 显示全部楼层 |阅读模式 来自 湖北武汉
Whenever a translation (rotation) dof at a node is constrained by a kinematic coupling definition the translation (rotation) dofs for that node cannot be included in any other constraint including mpcs, rigid bodies, etc.
 楼主| 发表于 2021-5-7 15:19:13 | 显示全部楼层 来自 湖北武汉
For *tie pair (assembly_s_surf-68-assembly_m_surf-45), adjusted nodes with very small adjustments were not printed. Specify *preprint,model=yes for complete printout.
For *tie pair (assembly_m_surf-63-assembly_s_surf-75), adjusted nodes with very small adjustments were not printed. Specify *preprint,model=yes for complete printout.
For *tie pair (assembly_m_surf-65-assembly_s_surf-76), adjusted nodes with very small adjustments were not printed. Specify *preprint,model=yes for complete printout.
For *tie pair (assembly_m_surf-55-assembly_s_surf-78), adjusted nodes with very small adjustments were not printed. Specify *preprint,model=yes for complete printout.
For *tie pair (assembly_m_surf-57-assembly_s_surf-77), adjusted nodes with very small adjustments were not printed. Specify *preprint,model=yes for complete printout.
MPCS (EXTERNAL or INTERNAL, including those generated from rigid body definitions), KINEMATIC COUPLINGS, AND/OR EQUATIONS WILL ACTIVATE ADDITIONAL DEGREES OF FREEDOM
警告信息有这些,哪位大神有这方面的经验指点一下
发表于 2021-5-8 11:17:21 | 显示全部楼层 来自 湖北
有偿解决ABAQUS分析问题,需要时可加2797871439
GMT+8, 2024-10-1 08:22 , Processed in 0.028470 second(s), 11 queries , Gzip On, MemCache On.
