- 2009-11-4
Assigning previously defined nodes to a node set
Input File Usage:
*NSET, NSET=name
For example, the following lines add nodes 1, 3, 10, 11, and all the nodes in set A11 to set A12:
*NSET, NSET=A12
1, 3
10, 11,
A11
Node set A11 can be assigned to node set A12 only if the definition of A11 occurs before the definition of A12.
All the nodes in node set A12 will be sorted into ascending numerical order.
Input File Usage:
*NSET, NSET=name, GENERATE
For example, the following lines add all nodes from 100 to 120 in increments of 10 to set A13:
*NSET, NSET=A13, GENERATE
100, 120, 10
Input File Usage:
*NSET, NSET=name, ELSET=name
For example, the following lines add all nodes that define elements 50 and 100 (nodes 1, 2, 3, and 4) to node set A14:
*ELEMENT, TYPE=B21
50, 1, 2
100, 3, 4
*ELSET, ELSET=B1
50, 100
*NSET, NSET=A14, ELSET=B1
Element set B1 can be assigned to node set A14 since the definition of B1 occurs before the definition of A14. |
