- 2009-11-4
学习记录Abaqus Topology Optimization Tutorial--ABAQUS
1 模型
定义节点,网格;节点集,单元集;
定义材料,赋予;
2 设定任务
Task->Create...
3 设计响应
Design Response->Create...
4 目标函数
Objective Function-Create...
5 约束条件
Constraint->Create...
转到Job模块
创建优化作业
操作过程:
一 建立节点、网格;定义节点集、单元集;
二 设置材料、赋予材料;
Module: Property
三 设置分析步;
Module: Step
四 设置载荷,边界条件;
Module: Load
五 提交作业
Module: Job->Create...Submit
六 设置优化任务
Module: Optimization
Create Optimization Task->Topology optimization->Continue...选择区域,接受默认设置,OK;
七 设置设计响应
Create Optimization Task->Create Design Response->Name:SE;Type:Single-term->Continue...Select the design response region type:Whole Model->Variable:Strain energy,OK
Create Optimization Task->Create Design Response->Name:VF;Type:Single-term->Continue...Select the design response region type:Whole Model->Variable:Volume,OK
八 设置目标函数
Create Objective Function->Target:Minimize design response values->Design Response,Name:SE,OK
九 设置约束条件
Create Constraint->Continue...Name:VF->Constrain the response to: Afraction of the initial value <=:.3,OK
十 创建优化作业
Module: Job
Create Optimization Task->Optimization,Controls,Maximum cycles:50;Data save:Every cycle
