- 2009-11-4
Overview
A node-based “surface”: can be used only as a “slave surface” in contact calculations; can be used as a “slave” or “master surface” in a surface-based tie constraint; is convenient in three-dimensional cases where Abaqus cannot construct a unique physical surface on the elements, such as a pipe modeled with pipe elements contacting the ocean floor or cables modeled with trusses contacting the ground after they break; Others
Creating a node-based surfaceYou create a node-based surface by specifying the nodes or node sets that form the surface.
You must assign a name to the node-based surface; this name will be used when defining contact interactions that involve the surface.
An optional associated area can be defined for each node. If no area is defined for a node and the surface is defined in a contact pair, the area specified as part of the contact property definition is used. If no area is specified as part of the contact property definition, a unit area is used.
Input File Usage:
*SURFACE, NAME=name, TYPE=NODE
node number or node set, area
例如:
*Nset, nset=SURF4
1, 12, 17, 172, 197, 522, 572, 597, 622, 672, 697, 722, 1772
*Surface, type=NODE, name=SURF
SURF4, 1.
