查看: 79|回复: 0
[INP文件] Element-based surface 基于单元的表面[4]/学习整理
发表于 2021-8-16 07:51:32 | 显示全部楼层 |阅读模式 来自 中国
Trimming the perimeter of an open surface
An “open” surface is one that has ends in two dimensions or an outside edge in three dimensions. The ends of a two-dimensional surface and the edge of a three-dimensional surface are called the surface's “perimeter.” Since Abaqus allows a surface to be defined as only a part of the surface of a body, it may have a perimeter even though it is defined on a closed body. Abaqus automatically performs surface “trimming” on solid element meshes. You can change the default setting when a surface is created, providing some basic control over the extent of surfaces.
Surface trimming:
is a recursive procedure that removes undesirable convex corners near the perimeter of an open surface (see the example below for details);
has no effect on closed surfaces (ones with no ends or edges);
is performed automatically, unless the surface is used as a master surface in a finite-sliding simulation in Abaqus/Standard or the surface is used with the contact pair algorithm in Abaqus/Explicit;
can be used only for external surfaces on solid element meshes (either specified surfaces or automatically generated free surfaces); and
has no effect on surfaces used with the contact pair algorithm in Abaqus/Explicit.
Input File Usage:
Use the following option to suppress automatic surface trimming:
*SURFACE, TYPE=ELEMENT, NAME=surface_name, TRIM=NO
GMT+8, 2024-6-30 06:47 , Processed in 0.025265 second(s), 10 queries , Gzip On, MemCache On.
