查看: 189|回复: 1
【讨论】ABAQUS running problem
发表于 2003-12-1 22:39:31 | 显示全部楼层 |阅读模式 来自 瑞士
I run a model in my C: disk using ABAQUS ,It had about 17.5GB
  but only about 4 GB free.
  The model was running till 5th step out of 45 steps
  and then there was an error due to lack of space of
  the disk.
  I copied ABAQUS and my inp.file to D: with 15 GB free
  space, and then when I wanted to run it there was an
  error in the very begining of the process saying that
  the analysis ended with error and that I should check
  disk capacity to see if I have enough capacity!!!While
  I had less capacity in C: and there was no messages!
  I have already increased the pre and standard memory
  in env.file which I don't think is important in this
  case.
  Could you help me with that?How can I get enough space
  for the analysis?
发表于 2003-12-1 23:47:07 | 显示全部楼层 来自 江苏南京
回复: 【讨论】ABAQUS running problem
bobo wrote:
  I copied ABAQUS
what have you copied ?why you copied ABAQUS to D:?
  how do you run your inp?in CAE or command?
if in command,have you change the work directory from c: to D:?
GMT+8, 2024-10-1 03:34 , Processed in 0.032025 second(s), 10 queries , Gzip On, MemCache On.
