查看: 426|回复: 4
【分享】Solving Mech Problem in Deform3D Ver 5.0
发表于 2004-2-4 06:10:37 | 显示全部楼层 |阅读模式 来自 新加坡
I need to correct my talk above since I can use mesh in Deform-3D Ver 5.0. This is because this program was written in UNIX so that it can not recognize the "space" on Window system when the main prrgram call the sub-program for mesh or fix geometry. Therefore, you need to install the software under your driver such as
C:\Deform3d  <=== OK
C:\Program  Files\Deform3d  <==== ERROR
     "Space" Problem
发表于 2004-2-4 09:28:18 | 显示全部楼层 来自 华南理工大学
回复: 【分享】Solving Mech Problem in Deform3D Ver 5.0
i don't think so. because i installed deform3d just under the root directory of c:.
its crack is imperfect i think.
发表于 2004-2-4 10:17:53 | 显示全部楼层 来自 江苏南京
yeah, It can be run.
Thanks for your sharing
xx(以为运行了,还是不行xx(
发表于 2004-2-5 21:07:27 | 显示全部楼层 来自 江苏南京
如果3D5.0的计算有问题请站内发消息给我。
再次感谢drlin   。:X
发表于 2004-2-11 14:26:31 | 显示全部楼层 来自 湖北武汉
no mesh and no run
3d5.0 deform 可爱又可恨, 帮帮我吧
send me a e_mail whj_hb@163.com
GMT+8, 2026-1-7 04:43 , Processed in 0.037266 second(s), 19 queries , Gzip On, MemCache On.
