- 4
- 2003-5-9
楼主 |
发表于 2004-2-12 19:39:45
来自 大连理工大学
回复: 【求助】一个隧道开挖的例子的inp文件的问题
at first ,say thanks to you .with your helping i found and solved my problem.and i also found others problem.in fact ,in a inp file ,it is not permitted that there are much more blank line.if there are much more blank line ,the abaqus maybe not solve the problem and cannot work the inp file.i dont know what i said is right,but with my remove the blank line and corrected the wrong as your guidance ,the inp file can fly .and i am glad so for it. |
