两块物体接触(如图),接触对建立了,TCC是接触热阻,施加了温度,
但是可以看到两块物体之间的传导没发生,(因为接触面之间的温度差别太大了), 如何来调整呢?
我参考的是VM23的例子。/prep7
Antype,0
mp,prxy,,0.3
/title, FENXI
!thopt,quasi
!eqslv,jcg
et, 1,solid5
et,2,targe170
et,3,conta174
KEYOPT,3,1,1
KEYOPT,3,12,5
mp,ex,1,2e10
MP,KXX,1,75 ! CONDUCTIVITY
MP,ALPX,1,12E-6 ! THERMAL EXPANSION COEFFICIENT
MP,MU,1,0.3
!mp,nuxy,1,0.30
R,2,,,,0.01 ,,
RMORE,,,,, ,
RMORE,,5.28e-4,,, 0, !TCC=5.28e-4
RMORE,,,,, ,
R,3,,,,0.01 ,,
RMORE,,,,, ,
RMORE,,,,, ,
R,4,,,,0.01 ,,
RMORE,,,,, ,
RMORE,,,,, ,
x=0
y=0
k,1,0,0
k,2,10,0
k,3,10,10
k,4,24,10
k,5,24,45
k,6,0,45
k,7,24,18
k,8,24,22
local,11,1,24,20,,90
l,7,8
csys,0
l,1,2
l,2,3
l,3,4
l,4,7
l,8,5
l,5,6
l,6,1
!SAVE
LFILLT,3,4,2, ,
LFILLT,4,5,1, ,
LFILLT,3,2,1, ,
lsel,s,line,,all
al,all
k,15,0,-4
k,16,10+x,-2
k,17,10+x,10-y
k,18,26+x,10-y
k,19,26+x,20
k,20,24+x,22
k,21,24+x,45
k,22,54+x,45
k,23,54+x,20
k,24,14,-14
k,25,0,-14
local,12,1,24+x,20,,-90
l,19,20
csys,0
l,15,16
l,16,17
l,17,18
l,18,19
l,20,21
l,21,22
l,22,23
l,23,24
l,24,25
l,25,15
LFILLT,13,14,2, ,
LFILLT,14,15,2, ,
lsel,s,line,,12,24,1
al,all
ALLSEL,ALL
esize,2,0
type,1
!rotate area into volume by axil
asel,s,area,,1,2,1
VROTAT,all,,,,,,25,6,30, ,
!control the work plane space
WPSTYLE,,,,,,,,1
wpstyle,0.1,0.1,-50,50,0.003,0,0,,5
wpro,,90.000000
!substrct volume for meshing easily
CYL4, , ,4, , , ,80
VGEN, ,3, , , ,60, , , ,1
vsel,s,,,1
vsel,a,,,2
vsel,a,,,3
vsbv,all,3
allsel
wpof,,,-10.000000
bopt,numb,off
! DIVIDE THE VOLUME BY WORK PLANE
VSBW, 4
vsbw, 5
/PNUM,VOLU,1
wpof,,,-8.000000
VSBW, 2
wpof,,,-4.000000
VSBW, 5
VSBW, 3
/REPLOT
wpof,,,24
vsbw, 4
VSWEEP,all ! mesh all volumes
/view,1,1,1,1
/REPLOT
WPSTYLE,,,,,,,,0
allsel
mat,3
real,2
! Generate the target1 surface
asel,s,,,8
cm,target1,area
type,2
nsla,s,1
esln,s,0
esurf,all
! Generate the contact1 surface
asel,s,,,22
cm,contact1,area
type,3
nsla,s,1,
esln,s,0
esurf,all
allsel
mat,3
real,3
! Generate the target2 surface
asel,s,,,10
cm,target1,area
type,2
nsla,s,1
esln,s,0
esurf,all
! Generate the contact2 surface
asel,s,,,24
cm,contact1,area
type,3
nsla,s,1,
esln,s,0
esurf,all
allsel
mat,3
real,4
! Generate the target3 surface
asel,s,,,4
cm,target1,area
type,2
nsla,s,1
esln,s,0
esurf,all
! Generate the contact3 surface
asel,s,,,15
cm,contact1,area
type,3
nsla,s,1,
esln,s,0
esurf,all
allsel
/solu
asel,s,,,31 ! area of top bottom
asel,a,,,16
nsla,s,1
d,all,temp,100
allsel
!area of bottom touch the rock
asel,s,,,26
asel,a,,,54
asel,a,,,17
asel,a,,,36
nsla,s,1
d,all,temp,160
allsel
asel,s,,,48,49,1
nsla,s,1
d,all,temp,140
allsel
! area of inside
asel,s,,,38
asel,a,,,2
asel,a,,,41,47,3
nsla,s,1
d,all,temp,60
allsel
/solu
solve |
