查看: 289|回复: 10
【讨论】请高手帮忙!焊接温度场的分析!
发表于 2004-4-15 15:19:28 | 显示全部楼层 |阅读模式 来自 武汉大学
平板堆焊
建模采用了完整模型的一半,焊缝按半球形,建模后是四分之一球形,热流服从高斯分布。采用plane55单元。
有很多问题,请高手帮忙!
FINI
/CLE
/PREP7
ET,1,PLANE55
MPTEMP,,,,,,,,
MPTEMP,1,0
MPDATA,KXX,1,,20
MPTEMP,,,,,,,,
MPTEMP,1,0
MPDATA,C,1,,0.5
MPTEMP,,,,,,,,
MPTEMP,1,0
MPDATA,KXX,2,,30
MPTEMP,,,,,,,,
MPTEMP,1,0
MPDATA,C,2,,0.6
*AFUN,DEG
CYL4,0,0,0,0,6,90
RECTNG,0,6,0,-20,
RECTNG,6,100,0,-20,
FLST,2,3,5,ORDE,2
FITEM,2,1
FITEM,2,-3
AGLUE,P51X
ALLSEL,ALL
ASEL,S , , ,       1
AATT,       1, ,   1,       0,
LESIZE,1, , ,50, , , , ,0
LESIZE,2, , ,30, , , , ,0
LESIZE,3, , ,30, , , , ,0
MSHAPE,1,2D
MSHKEY,0
AMESH,1
CM,_Y,AREA
ASEL, , , ,       4
CM,_Y1,AREA
CMSEL,S,_Y
CMSEL,S,_Y1
AATT,       2, ,   1,       0,
CMSEL,S,_Y
CMDELE,_Y
CMDELE,_Y1
/AUTO,1
/REP,FAST
CM,_Y,AREA
ASEL, , , ,       4
CM,_Y1,AREA
CMSEL,S,_Y
CMSEL,S,_Y1
AATT,       2, ,   1,       0,
CMSEL,S,_Y
CMDELE,_Y
CMDELE,_Y1
FLST,5,2,4,ORDE,2
FITEM,5,3
FITEM,5,-4
CM,_Y,LINE
LSEL, , , ,P51X
CM,_Y1,LINE
CMSEL,,_Y
LESIZE,_Y1, , ,30, , , , ,1
FLST,5,2,4,ORDE,2
FITEM,5,12
FITEM,5,-13
CM,_Y,LINE
LSEL, , , ,P51X
CM,_Y1,LINE
CMSEL,,_Y
FLST,5,2,4,ORDE,2
FITEM,5,12
FITEM,5,-13
CM,_Y,LINE
LSEL, , , ,P51X
CM,_Y1,LINE
CMSEL,,_Y
CM,_Y,AREA
ASEL, , , ,       4
CM,_Y1,AREA
CHKMSH,'AREA'
CMSEL,S,_Y
AMESH,_Y1
CMDELE,_Y
CMDELE,_Y1
CMDELE,_Y2
GPLOT
CM,_Y,AREA
ASEL, , , ,       5
CM,_Y1,AREA
CMSEL,S,_Y
CMSEL,S,_Y1
AATT,       2, ,   1,       0,
CMSEL,S,_Y
CMDELE,_Y
CMDELE,_Y1
FLST,5,2,4,ORDE,2
FITEM,5,14
FITEM,5,-15
CM,_Y,LINE
LSEL, , , ,P51X
CM,_Y1,LINE
CMSEL,,_Y
FLST,5,2,4,ORDE,2
FITEM,5,9
FITEM,5,12
CM,_Y,LINE
LSEL, , , ,P51X
CM,_Y1,LINE
CMSEL,,_Y
CM,_Y,AREA
ASEL, , , ,       5
CM,_Y1,AREA
CHKMSH,'AREA'
CMSEL,S,_Y
AMESH,_Y1
CMDELE,_Y
CMDELE,_Y1
CMDELE,_Y2
FLST,2,2,5,ORDE,2
FITEM,2,4
FITEM,2,-5
ACLEAR,P51X
GPLOT
CM,_Y,AREA
ASEL, , , ,       4
CM,_Y1,AREA
CMSEL,S,_Y
CMSEL,S,_Y1
AATT,       2, ,   1,       0,
CMSEL,S,_Y
CMDELE,_Y
CMDELE,_Y1
FLST,5,2,4,ORDE,2
FITEM,5,3
FITEM,5,-4
CM,_Y,LINE
LSEL, , , ,P51X
CM,_Y1,LINE
CMSEL,,_Y
FLST,5,2,4,ORDE,2
FITEM,5,12
FITEM,5,-13
CM,_Y,LINE
LSEL, , , ,P51X
CM,_Y1,LINE
CMSEL,,_Y
CM,_Y,AREA
ASEL, , , ,       4
CM,_Y1,AREA
CHKMSH,'AREA'
CMSEL,S,_Y
AMESH,_Y1
CMDELE,_Y
CMDELE,_Y1
CMDELE,_Y2
GPLOT
CM,_Y,AREA
ASEL, , , ,       5
CM,_Y1,AREA
CMSEL,S,_Y
CMSEL,S,_Y1
AATT,       2, ,   1,       0,
CMSEL,S,_Y
CMDELE,_Y
CMDELE,_Y1
FLST,5,2,4,ORDE,2
FITEM,5,9
FITEM,5,12
CM,_Y,LINE
LSEL, , , ,P51X
CM,_Y1,LINE
CMSEL,,_Y
FLST,5,2,4,ORDE,2
FITEM,5,14
FITEM,5,-15
CM,_Y,LINE
LSEL, , , ,P51X
CM,_Y1,LINE
CMSEL,,_Y
CM,_Y,AREA
ASEL, , , ,       5
CM,_Y1,AREA
CHKMSH,'AREA'
CMSEL,S,_Y
AMESH,_Y1
CMDELE,_Y
CMDELE,_Y1
CMDELE,_Y2
ALLSEL,ALL
FINISH
/SOLU
ANTYPE,4
TRNOPT,FULL
LUMPM,0
CSYS,1
wpstyle,0.05,0.1,-1,1,0.003,1,2,,5
ALLSEL,ALL
*DO,I,1,30,1
NSEL,S,LOC,X,0.2*(I-1) ,0.2*I
NSEL,R,LOC,Y,0,90
ESLN,R
SFE,ALL,,HFLUX, ,900*exp(-1.3*(0.2*(I-1)*(I-1))), , ,
ALLSEL,ALL
*ENDDO
ALLSEL,ALL
wpstyle,0.05,0.1,-1,1,0.003,0,2,,5
OUTPR,BASIC,ALL,
TIME,60
SOLVE
kimmybaby 该用户已被删除
发表于 2004-4-16 15:31:42 | 显示全部楼层 来自 湖北武汉
提示: 作者被禁止或删除 内容自动屏蔽
发表于 2004-4-16 18:35:33 | 显示全部楼层 来自 河南郑州
回复: 【讨论】请高手帮忙!焊接温度场的分析!
也许别人很忙,没时间把命令流跑一遍,你干脆把出现的问题描述一下,如果是经常遇到的典型问题,就直接回复了。
 楼主| 发表于 2004-4-17 07:12:52 | 显示全部楼层 来自 武汉大学
问题是焊缝有彩云显示,而平板没有任何变化!
这是怎么回事?已经粘在一起了呀!
发表于 2004-4-17 21:36:51 | 显示全部楼层 来自 北京
1、你看看单位是否统一,比如导热系数的单位是否和后面其他物理量的单位一致?可能是你的导热系数太小了,所以热传导的作用就不明显了;
2、你把加载的热源加大十倍或者几十倍,看看结果是否还是平板没有变化。
如果还是不行,大家再帮你想想其他的原因。
发表于 2004-4-17 22:05:46 | 显示全部楼层 来自 河南郑州
后处理中分开选取焊缝区域或平板区域,再PLOT看看。
 楼主| 发表于 2004-4-18 04:51:44 | 显示全部楼层 来自 武汉大学
多谢二位了
我试一下
 楼主| 发表于 2004-4-18 10:21:12 | 显示全部楼层 来自 武汉大学
可能我的一些参数,比如热导率、密度等没有设好,我算的时候都是自己估计的数字!
那么,请问,关于这些参数,DENS、KXX、C都是在哪里查呀?
如果关于温度变化,变化的值又怎么算?
深表感谢!
 楼主| 发表于 2004-4-18 15:55:02 | 显示全部楼层 来自 武汉大学
再问:
     关于焊接后热过程中氢的扩散,它加的边界条件同温度场一样!也就是说可以按照设定温度场分析那样设置边界条件。
    因为氢的扩散区域非常小,所以,按恒温扩散考虑。假设那个区域温度是1000℃,区域大小已知。那么,怎么才能把氢的扩散彩云图算出来?
发表于 2004-4-18 16:49:07 | 显示全部楼层 来自 北京
用自己估计的数字当然不可以了,去图书馆找一些专业的书籍,金属材料手册之类的,应该都有介绍的。
氢的扩散彩云图?你是说后处理吧?如果和温度场差不多的话,就用plot ctrls->nodal solution 显示,想看具体节点的数值,用list命令,你试试吧!
发表于 2010-5-24 09:16:17 | 显示全部楼层 来自 内蒙古包头
xuexi le     dd
GMT+8, 2024-9-20 19:43 , Processed in 0.045115 second(s), 12 queries , Gzip On, MemCache On.
