我用VOF模拟幂率流体沿平面扩散。两种流体:幂率型(胶),空气;边界为1/4椭圆弧。但怎么弄就是不行。将VOF流体材料换成Constant型,其它没动,居然行了!
联想到Adina自带的大坝泄水的例子,我又将 prob32.in 打开,在确定该模型能计算下去的情况下,将水换成了幂率型的胶,其它都没动,但计算时同样的问题又出来了(如下),然后立刻终止。
Starting Solution Process ...
*** ERROR *** CODE ADF2003:
Error encountered while reading data block (code 1400):
"ELEMENT GROUP DATA OF ELEMENT GROUP 1 from <fluid>.dat file".
Last input data block is:
Data could be wrong somewhere between the two data blocks.
This could mean an internal error or a wrong data file was used.
Number of errors = 1
Please search "ERROR" and "WARNING" in the *.out file for explanations
ENDCODE=1 010 0
Error encountered ...
Releasing network license ...
Job Canceled on Sat Jun 05 20:38:11 2004
