- 84
- 2003-5-22
发表于 2004-6-23 14:38:53
来自 日本
回复: 回复: 【讨论】abaqus中有无等价于ansys的APDL语言?
wangfjy wrote:
Cafe0519,
In ansys, I can easily change the materials properties in the solution process and go on the periodic solution with the *do command.
the example in the attached file will be a typical method and can be easily written with the traditional Fortran format.
However, the above function will not to be easily achieved by abaqus. Is it possible to have these function by abaqus? Please give me some advice.
Thank you!
In python, i can finish the periodic process of MAT change in CAE, but you would be very familiar with the ODB access.
Before that, I used a small program (coded in F90) to generate a list of MAT i need in the analysis, then automatically form and include these MAT files into your main INP file. Finally, write a batch command to do your periodic solution. It is easily controlled by your own script.
you can have a try. |
