- 3
- 2004-5-24
象这种情况,跨中产生较大局部屈曲,存在较大塑性应变,壁宽厚比在25-40之间的情况,该选用何种壳元合适呢,高手帮小弟出出招吧。
谢谢,了
S3 3-node triangular general-purpose shell, finite membrane strains (identical to element S3R) (Section 15.6.7)
S3R 3-node triangular general-purpose shell, finite membrane strains (identical to element S3) (Section 15.6.7)
S4 4-node doubly curved general-purpose shell, finite membrane strains (Section 15.6.7)
S4R 4-node doubly curved general-purpose shell, reduced integration, hourglass control, finite membrane strains (Section 15.6.7)
S4R5 4-node doubly curved thin shell, reduced integration, hourglass control, using five degrees of freedom per node (Section 15.6.7)
S8R 8-node doubly curved thick shell, reduced integration (Section 15.6.7)
S8R5 8-node doubly curved thin shell, reduced integration, using five degrees of freedom per node (Section 15.6.7)
S8RT 8-node thermally coupled quadrilateral general thick shell, biquadratic displacement, bilinear temperature in the shell surface (Section 15.6.7)
S9R5 9-node doubly curved thin shell, reduced integration, using five degrees of freedom per node (Section 15.6.7)
SAX1 2-node linear axisymmetric thin or thick shell (Section 15.6.9)
SAX2 3-node quadratic axisymmetric thin or thick shell (Section 15.6.9)
SAX2T 3-node axisymmetric thermally coupled thin or thick shell, quadratic displacement, linear temperature in the shell surface (Section 15.6.9)
SAXA1N Linear asymmetric-axisymmetric, Fourier shell element with 2 nodes in the generator direction and N Fourier modes (Section 15.6.10)
SAXA2N Quadratic asymmetric-axisymmetric, Fourier shell element with 3 nodes in the generator direction and N Fourier modes (Section 15.6.10)
SC6R 6-node triangular in-plane continuum shell wedge, general-purpose continuum shell, finite membrane strains. (Section 15.6.8)
SC8R 8-node quadrilateral in-plane general-purpose continuum shell, reduced integration with hourglass control, finite membrane strains. (Section 15.6.8)
SFM3D3 3-node triangular surface element (Section 18.2.2)
SFM3D4 4-node quadrilateral surface element (Section 18.2.2)
SFM3D4R 4-node quadrilateral surface element, reduced integration (Section 18.2.2)
SFM3D6 6-node triangular surface element (Section 18.2.2)
SFM3D8 8-node quadrilateral surface element (Section 18.2.2)
SFM3D8R 8-node quadrilateral surface element, reduced integration (Section 18.2.2)
SFMAX1 2-node linear axisymmetric surface element (Section 18.2.4)
SFMAX2 3-node quadratic axisymmetric surface element (Section 18.2.4)
SFMCL6 6-node cylindrical surface element (Section 18.2.3)
SFMCL9 9-node cylindrical surface element (Section 18.2.3)
SFMGAX1 2-node linear axisymmetric surface element, twist (Section 18.2.4)
SFMGAX2 3-node quadratic axisymmetric surface element, twist (Section 18.2.4)
SPRING1 Spring between a node and ground, acting in a fixed direction (Section 17.2.2)
SPRING2 Spring between two nodes, acting in a fixed direction (Section 17.2.2)
SPRINGA Axial spring between two nodes, whose line of action is the line joining the two nodes. This line of action may rotate in large-displacement analysis. (Section 17.2.2)
STRI3 3-node triangular facet thin shell (Section 15.6.7)
STRI65 6-node triangular thin shell, using five degrees of freedom per node (Section 15.6.7) |
